I was limited to only those few photos of the project but now I will finish the rest of the progress that I made earlier today..Cheers everyone!
Looks good and stout. You are bolting that to the frame right? Gonna put the bikes and such on it?
MM180
SP125+
That's a possibility. I could put the bikes on the Rear now that I don't need a separate Trailer. The original RV generator is loud and Vibrates alot so I have plans to put four wheels on the generator on the bumper and just set it about 25' away so there's no noise. Yes My Tote Gote would do well in the front.
Hey there martoli,
Looks pretty good. And better than those carriers you slip into a Reese type hitch with only one tube.They just seem to shake around alot. Yours look like that problem is solved.
Thanks Urch! I follow some RV'ers up the hills sometimes and they have their generators on those Harbor Freight Rear Hitch Carriers and I Just watch in Awe how they Tilt and Sway back and forth as they make their turns. Hopefully with any Luck this mount will tilt the RV forward some to level the rear so I can have the weight distributed evenly.![]()
