Results 1 to 9 of 9
    Jun 2010
    Seguin, Tx
    145
    Smile Please help, Jeff's CNC Plasma Cutting
    Hi all, for about the last 25 years [off and on] I have been casting aluminum, brass and copper. Started out using charcoal to melt aluminum, have made a metal cutting lathe, works very well, [did not have the money to buy one], since then I started using and have made two other furnaces, one using LP gas and the other using 240v electric elements. I would like to know if someone knows of a way to control the heat, [without going to alot of expense], with digital electronics, heat range from 1200 degrees F to 2500 degrees F ? I can build it if someone has a readable schematic with all the values and parts list, although this might be to much to ask for, thought I
    would ask, thanks Jeff. I cast these parts to build my CNC plasma cutting machine.
    Jun 2010
    North Central Fla
    210
    Sorry Jeff, Cabt help ya on the controls, but those are some pretty casting for you machine anyway!!!!
    Bob
    Enough tools to do anything, common sense to use em properly.
    Big nasty scar, no kidneys, so you think you got issues?
    Jun 2010
    Seguin, Tx
    145
    Jeff's CNC plasma cutting
    Quote Originally Posted by Rbeckett View Post
    Bob
    Thanks for looking anyway, Jeff.
    Aug 2003
    Gillette, WY
    2,266
    Jeff,
    Try the link below for the Practical Machinist site. There may be someone on that site that could provide the information you are searching for.
    http://www.practicalmachinist.com/vb...a-welding-fab/
    Jun 2010
    Seguin, Tx
    145
    Quote Originally Posted by Wyoming View Post
    Jeff,
    Thanks Wyoming, I will check them out, Jeff.
    5,319
    There might be some good oven info here: http://forum.caswellplating.com/oven-building-forum/
    My son is going to build one soon. He got one of those $35 digital controllers. Do a search on JLD612 or TET612.
    EDIT: Check this thread:
    http://www.practicalmachinist.com/vb...ne-off-199644/
    Sep 2007
    Laramie, Wy.
    218
    Check out some of the powder coater forums. They have a lot of information about temperature controls, as it is critical to the process.
    The temperature ranges they deal with are far below your needs, but if you can get some feel for the makers of the digital controllers and follow that trail, you might find that they make what you need.
    Caswell
    Eastwood
    Powderbuythepound
    Powder365
    Lincoln Power MIG 140C Victor A/O
    Dewalt 14" Chop Saw IR 20gal 5hp Compressor
    Craftsman bench grinder, tabletop drill press
    Carton of Common Sense: Medium
    Box of Experience: Small
    List of things to learn: Long!
    Oh,, an old 360 Green Card and a 370 Yellow Green Card too..
    Jun 2010
    Seguin, Tx
    145
    Thanks guys I will look into this, Jeff.
    Jun 2010
    Seguin, Tx
    145
    Ha guys, I found just what I have been looking for, it will handle 2300 degrees F. Temp controller, t couple and ssr all under $200.00 @ lightobjects.com , cool stuff, thanks Jeff.
