Results 1 to 11 of 11
    Aug 2006
    Iowa
    452
    Question HB-28 Vs L56 Vs Hobart MIG Wire
    I sold my little Miller 140 AS (115 volt) and ended up with an older Miller 175 (230 volt) with very low miles. Using C25 gas for the welder and I just stuck in the 175 a partial small roll of HB-28 .030 that was in my 140.
    Just about out of that little roll and looking for something else. TSC has the Hobart brand wire .030 for $30 a 10 lb roll. Lowes has the Lincoln L-56 wire $40 for 12.5 lb roll, again .030. Sometime in the past I've used the HTP wire and had good luck so I could go that route.
    I see the Lincoln wire is no longer Made in USA.
    Since this model has no actual taps, can I adjust the voltage or wire speed when welding?
    Suggestions on the wire?
    Retired...
    Master Electrician
    Journeyman Refrigeration Pipefitter
    Semi-pro/Hobby Welder
    Miller MaxStar150 TIG/Stick Inverter
    Miller MM175 MIG
    Eastwood Plasma Cutter
    Victor Oxy/Acetylene
    EMCO Maximat - Super 11 Lathe
    Grizzly X3 Mill
    Northern Cal.
    1,508
    There's no garauntee the Hobart wire will be made in the USA either. If it's important read the box 1st. Other than country of origin I prefer the Hobart wire.
    No real data to back up why I like one over the other, I just do.
    May 2009
    Gulfport, Florida
    1,963
    George.
    You can do a lot better price wise on eBay. I buy .035 solid wire on a 44 pound spool for $60.00 and that includes shipping. It's made overseas but I can buy it for twice as much money here at my LWS and still get overseas made wire. And it welds just as good as USA wire, I just don't pay for a US name. It's a shame, get some thing half price from half way around the world.
    I would check the owners manual about adjusting volts. But I know you can adjust the wire speed while welding.
    Aug 2006
    Iowa
    452
    I don't think I could fit a 44lb spool in my welder if I wanted...but I never tried. My understanding is the Lincoln wire was pretty good, until they moved production to Mexico. I just want good MIG wire if I need to pay a couple more bucks thats ok.
    I would think since Hobart is also Miller that the wire they make would work fine... but since its made in China I assume, I was checking in with the folks on here to make sure it had not gone down in quality like the Lincoln wire.
    Retired...
    Master Electrician
    Miller MM175 MIG
    Grizzly X3 Mill
    5,204
    The .030 Hobart brand wire from China that I've ran has produced a clean arc and very good weld puddle wetout.
    L-56 has been inconsistent. One roll runs good, and the next roll produces some visible arc inconsistencies. Weld puddle wetout has been good. Actually, I just remembered a roll of L-56 that was running extremely well on a HH 187, ran like crap on a MM 180. The MM 175 and MM 180 arc characteristics are very similar.
    PM 180C
    Jun 2006
    Wichita, KS, USA
    4,102
    IIRC, the manual says not to adjust welder settings while welding.
    (edit: I can't find it in the manual anywhere, but it seems like I did read somewhere that it was not advised. I know it isn't on tapped machines... maybe that was what I was thinking of.)
    Good luck fitting anything bigger than an 8" spool inside the wire bay of the MM175. If I was doing more welding, I would probably consider a way to pipe the wire into the machine and use the bigger spool, but if I was doing that, I'd probably have a welder that was capable of handling the bigger spool in the first place. I have been buying 11 lb spools of 0.030" at my LWS for about $20. So far, I've not noticed a difference from one spool to the next, but I haven't had to change spools in the middle of a big job where it would be most apparent, either. I suppose going that route, YMMV.
    HTP does have wire on Ebay for about $36.50 shipped. That's 2 - 10# spools.
    P.S. - Hobart is not Miller, and Miller is not Hobart. Neither owns the other either. They just have the same parent company.
    MM180
    SP125+
    Aug 2006
    Iowa
    452
    Smile
    Yes, I know I can't use anything larger than the 10 - 12 lb spools and that's fine. I was just checking before I made a mistake and getting some wire that was c**p. Hate having this production all moved to China.
    Thanks for all the good answers, I guess I am headed to TSC to get the Hobart wire...
    Retired...
    Master Electrician
    Miller MM175 MIG
    Grizzly X3 Mill
    Mar 2006
    Texas
    65
    Download a manual from Millers website. I don't think you can adjust voltage on the fly.
    Jun 2006
    Wichita, KS, USA
    4,102
    I checked my MM180 and then looked at the MM175 manual and couldn't find any mention of it. I wouldn't be able to hold my gun hand steady enough to use my other to make adjustments on the fly anyway!
    MM180
    SP125+
    May 2009
    Gulfport, Florida
    1,963
    Quote Originally Posted by wmgeorge View Post
    George.
    I was not meaning for you to buy #44 spools. I was trying to bring out the deals you can get from eBay stores. You can get #10 spools for anywhere from $10 to $15 each if you look and compare. Most of the time you buy the #10 spools two at a time. Average cost would be $15 each.
    Aug 2006
    Iowa
    452
    For what little welding I do, a 10 # spool will last a year or so. Just hate buying those little 2# spools at $12 a crack, for the price of 2 I can get a larger one. Its so darn hot now, projects are on hold until it cools off.
    Retired...
    Master Electrician
    Miller MM175 MIG
    Grizzly X3 Mill
