For reasons that are not clear to me, our MIG welder has just been set up with a full bottle of pure argon and another with Helium tri-mix. What I mostly need to to is weld mild steel. I know that the argon is for aluminum and the tri-mix is for stainless steel (which we almost never encounter). What should I use for welding mild steel?
Given that I need to use the tri-mx up, can I use it with mild steel? Any suggestions on how to change the voltage and wire-speed settings from the suggested argon/CO2 mix?
Thanks.
