Results 1 to 14 of 14
    Apr 2009
    houston pa
    1,258
    trailer wheel spacers
    this is how i spent a good portion of my 4th of july.
    i bought a 12 foot triton flatbed aluminum trailer off of the people i work for. while the new tires they had put on were the same sidewall size as the old ones the new ones were 1/2" wider and were rubbing on the torsion bars.
    i made some spacers for the problem as i didnt want to get new tires and try to get rid of brand new trailer tires. i think that this is illegal but i only went with 1/8 inch spacers and wont go more if these dont work. ill probably check the torque after each use anyway.
    this was my first attempt at making a circle cutter and it was flawed to 1/32.
    Jun 2006
    Wichita, KS, USA
    4,102
    Looks good. I don't know about legality, but as long as you have all the threads in the lugnuts engaged, I'd say they should work just fine.
    Red (not lincoln) inverter TIG/Stick
    MM180
    SP125+
    May 2009
    Gulfport, Florida
    1,963
    I don't know why they would be illegal.
    I personally would not have a problem with wider spacers as long as you don't run out of threads on the stud.
    Mar 2010
    SE Michigan
    2,042
    I've done worse on farm implements. I've used hacksawed pipe nipples for spacers. Actually, the left rim on my square bailer still has the nipples between the rim and hub.... Been that way for years.
    So little time...So many machine tools.........
    www.flipmeisters.com
    Miller, Hobart & Lincoln TIG/MIG/-
    Hypertherm Plasma (Thanks Jim)
    Plasma-Cam DHC (coming shortly)
    Harris OA
    Too many motorcycles.............-
    Dec 2005
    S.E. Wisconsin
    78
    Any modification to a stock wheel for street use is technically illegal. But a backing plate is commonly welded to to wheels used for racing for added strenght in the lug nut area.
    May 2009
    Gulfport, Florida
    1,963
    Quote Originally Posted by triptester View Post
    Trip.
    "Technically" The wheel is not modified. The spacer is sandwiched between the hub and wheel, no mention of welding it to the wheel.
    Mar 2008
    16
    Were the wheels "hub centered" ? If so, Have the spacers unplugged the hub pilot from the wheel?
    Apr 2009
    houston pa
    1,258
    lug centered. thats a good point that you bring up though and i could see how it might be easily overlooked until the test ride.
    Apr 2009
    houston pa
    1,258
    well, if luck was on your side and you gave the wheel a spin by hand im sure the wobble would be obvious then and there before a test ride.
    Mar 2012
    5
    These are available for ~$10-12 at just about any parts store.
    Apr 2009
    houston pa
    1,258
    get out of town! obviously i didnt know that. i have to wonder why they have them though.
    the only ones ive ever seen were for jeeps or a recall modification and they were pretty pricey.
    Mar 2012
    5
    I can't tell if you're being sarcastic or not, but if you don't need them to be hub-centric, or so thick that they need a second set of wheel studs (i.e. adapter style spacers), then they are pretty readily available.
    BTW.. does anyone else seem to have a delay between what they type and when it shows up in the reply box? Especially deleting, it seems very sluggish... Maybe it's our network or something.
    Apr 2009
    houston pa
    1,258
    no, i wasnt being sarcastic. i usually am though.
    even considering napa being 5 miles from home if they wanted more than $10 for a set id just rather be at home making them instead of going there. ill probably never have need for spacers again but im glad you told me they are readily available.
    Mar 2012
    5
    Got ya. Yeah, they probably would be a little north of $10 in the end, but maybe not $10 more than the material used to fab them. They do make them in steel (I can't remember if it was topline or Mr.G that did, it's been a while since my speed shop days) and aluminum... which you probably want to stay away from aluminum-on-steel or on-iron due to the galvanic reaction.
