Results 1 to 12 of 12
    May 2010
    30
    "Y" adapter for sharing argon
    I got a new HH 210 and already have argon with my TIG outfit and was thinking about the possibility of sharing the argon with the HH 210. I believe they make a "Y" to do such a thing but was curious how many people do that and how it works. Does the "Y" adapter have 2 valves so you can use one or the other?
    Thanks in advance,
    schemer
    11,282
    I do it with mine, I put a Y after the flowmeter and use the same bottle for alum.
    May 2010
    30
    Thanks for the info and the pic. So about $40 is a fair price for one of these?
    schemer
    11,282
    I would say, with valves, you can get by without them if needed though. But they cant hurt and I guess I just happened to have them on this Y.
    While you can do that, you won;t get good results using straight argon in your MIG...A mix of 75/25, called C25 works best in a MIG.
    May 2010
    30
    Quote Originally Posted by Rocky D View Post
    Hey Rocky,
    I know...I already bought the 300 cu ft bottle (well rented it anyhow), for the MIG but I got the super deal from TSC that included the spool gun so I may want to try it with aluminum at some point although I already have a TIG welder. I was going to buy C15 but they didn't have it...but spray welding is another story.
    Thanks for looking out for me though.
    schemer
    May 2010
    30
    Quote Originally Posted by Sberry View Post
    Thanks Sberry,
    I will source one when the time is right. I will go with the valves.
    schemer
    Nov 2002
    SW. Ontario, Canada
    98
    Looking to twin my 2 migs together and use the same regulator and cylinder. Anyone have a name or parts number so I purchase one ? Any help is appreciated.
    5,318
    These folks make various types:
    http://www.westernenterprises.com/en...ses/fit_y.php#
    Available here, among other places:
    https://weldingsupply.securesites.co...41:UNDEF::::PJ
    chico, ca
    518
    Quote Originally Posted by Farmer View Post
    i bought mine with valves at air gas. radnor brand...part#rad 64003946. $32.00. i use it on my mm252 to tie the gas into both the machine and spool gun.
    tc.....jim
    miller bobcat 225
    miller AEAD200LE with hf tig
    mm175, mm252 w/30a
    lincoln PT 225, mm211, TA181i
    stickmate LX 235/160
    Speedglas 9100X/9100XX/Miller DE
    hypertherm 380
    TD cutmaster 52
    steel max 14" & evolution 7.5" dry cut saws
    2 victor journeyman/3 superange, smith little, meco midget torches
    ridgid chop saw
    kalamazoo band saw/ 8-4.5" & 1 rockwell 9" grinder
    case 580 backhoe for things i can't lift
    if at first you don't succeed
    trash the b#####d (me )
    Nov 2002
    SW. Ontario, Canada
    98
    Thanks for the help guys. This will make my little upgrade much easier.
    5,318
    Does LENCO up there have anything that will work for you up there in Canuckistan? http://www.lencocanada.com/
