Results 1 to 4 of 4
Thread: (((((help)))))
    Apr 2010
    trevor,wi
    (((((help)))))
    I have an older kubota tractor where the front end of the drivetrain bolts up to the engine,is there anyone know or can tell me how to get this fixed.is this site legimate >www.muggyweld.com.. or the lincoln 55 ni rods ? i know the block is gray cast iron,and it needs to be welded in several spots,ill print some pics soon.help !!!!!!!!!!! need expert advice ! johnnybebad60085@yahoo.com
    S.E. Wisconsin
    4,544
    Thumbs up
    Hey you ain't too far away.
    Pics will help......
    Maybe I'll help too.
    Cheers
    VG
    May 2010
    what exactly can we do for you? please tell us more details.
    My father has some of them and it is an expert.
    Mar 2010
    SE Michigan
    2,042
    After 12 or so Kubota's I can say that most of the underpinnings are cast steel and weldable but you have to grind out the defective (crack) area and pre-heat beforehand. After you have done the repair, Kubota Grey Spray Paint hides the work really well.
    www.flipmeisters.com
    Harris OA
