    ct
    1,392
    Tig purchase help
    So I am in the market for a used Tig welder. Ideally I would like a Lincoln SW255 or a Miller Synrowave 250, but I would also consider an older Linde or Hobart even an Esab if the price was right.
    Here are a few questions. Do the older machines (transformers) draw more power then a say 5 year old transformer machine ? What should I look for when I go and look at a machine (besides welding with it ) What are the going prices for a good Tig ?
    Thanks -
    God Bless America
    Apr 2008
    North West Ontario Canada
    197
    Prices can vary greatly depending on if you need to be able to weld aluminum or not. If you don't need AC high frequency (aluminum), you can get a DC only machine that will tig steel and stainless steels for a very reasonable price. Lift start or scratch start does just fine.
    Once you include AC and high frequency requirements on a welding power source, the price goes up.
    Lincoln Idealarc 250 stick/tig
    Erickson&Erickson 200 Amp DC arc welder
    Century 70Amp Mig
    Thermal Dynamics Cusmaster 52
    Torchmate CNC Table
    5,312
    Looking at the Syncro 250 vs. the later 250DX, it looks like the newer model takes 3 Amps more @ 200A output (230v input, no power factor correction). Ideally these should be given a 100A breaker or thereabouts though we have ours on a 70.
    We got our 1993 vintage Syncro for $850. last summer. It was bare-bones but in nice condition, having come from some community college.
    ct
    1,392
    850.00 is a score and a half.
    How has it worked out for you ?
    God Bless America
    5,312
    My son hasn't used it all that much this winter but it works well. He found a lightly-used cooler which is a rebadged Coolmate 3 for about $300. The foot pedal came from SSC Controls. We probably have around $1,600. in it. All the pieces-parts can add up really quickly.
    We still need to rig up something to make it easy to swap from TIG to SMAW. We have the Dialarc, so it's not a priority.
