I have a 250 oxygen and a 125? acetylene tank for my torch setup. These are very heavy to wheel around.
I did not get a porta-torch since it would require frequent refills. Would there be any way for me to transfer (using some sort of hose setup) from the big tanks to smaller portable tanks (porta-torch size), if I purchased them?
The large tanks posted above would only be used to fill the little tanks.
John![]()
) - years ago, in another life, I worked at a drive-in theatre. The "rage" back then was Bernz propane in-car heaters for each car. This required a tank filling station which was in a small metal shed that was spaced about 6" off the ground to let any leaked propane escape. Quite a bit of gas would escape in the process of mounting/dismounting the small propane cylinders. We had one idiot that insisted on smoking while he was filling cylinders. Every time Charlie would fill cylinders we would always stay a safe distance away and be amazed at how he stayed alive. While he was filling cylinders we would always hear an occassional WHOOSH followed by a ball of fire rolling from underneath the "spaced up" metal shed. One time Charlie went to help one of the other guys fill cylinders on a fairly still day, when he walked up to the shed (with cigarette in hand) there was a BIG WHOOSH and big ball of fire. It was amazing how much a metal shed will expand without blowing apart. Scared the he?? out of both guys and Charlie never smoked around the filling station again. Neither guy was hurt, just a little singed hair and increased heart rates.
