Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: 100% Co2 MIG
  1. #16
    Oct 2007
    Vermont
    58
    A comparison between CO2, Argon/CO2 mix, Argoshield Light and pure Argon to find out which is the best on mild steel.
    http://www.mig-welding.co.uk/welding-gas.htm
    Paul in VT
  2. #17
    Oct 2007
    Vermont
    58
    Paul in VT
  3. #18
    Oct 2010
    38
    Straight CO2, deep penetration, more splatter, cheaper than C25. C25 much better weld appearance, no splatter. Have to be careful using straight CO2 in a closed area, headaches or worse.
  4. #19
    Jul 2011
    37
    I Like CO2
    I use CO2 for all my plate welding and thicker stuff as it seems to burn in better. Thin stuff not so good. The only time I have spatter problems is when my nozzle is clogged or my stick out is to long. It's a lot cheaper and I get more weld time with CO2 because it's a liquid as compared to an argon mix which is a gas. So far CO2 has worked well for me.
