Results 1 to 13 of 13
    Dec 2009
    24
    Problems with HH210
    Just got a new Handle 210 a couple days ago and got it running today. I have a couple gas leaks though. I can hear it hissing out of the hole on the gauge assembly where you adjust the flow rate. Also with the machine on or off not in use I can here gas coming out of the gun.
    What's up? Is it common?
    Mar 2009
    Los Angeles
    82
    There should be no gas leaks.
    Dec 2009
    24
    That's what I figured. LOL My luck to have a defective gauge and something in the welder.
    5,204
    You probably have a small piece of debris from the gas supply hose stuck in the in the gas valve. If you do a search you should be able to find past posts covering how to fix this issue.
    PM 180C
    Dec 2009
    24
    I found them and will try tomorrow and take the regulator back.
    Dec 2009
    24
    Got a replacement regulator today for the place I bought the welder. Also tried to blow out the gas solenoid and it didn't help. So I took it apart and found a small piece of debris holding the plunger from fully seating. All is well now!
    Austin TX
    4,861
    Quote Originally Posted by mikehussy1990 View Post
    first of all i should say .....
    First of all, perhaps you should read the post right above yours where the OP says he's solved the problem already...
    Hobart HH 125EZ
    Los Angeles
    5,476
    I think Mike be a Spammer.
    MM252
    MM211
    SO 2020 Bender
    Austin TX
    4,861
    Yeah, I think so too. I reported him the first time he showed up here but the powers that be left him alone... his posts are all generic and pointless.
    Hobart HH 125EZ
    Dec 2005
    Lodi, CA
    1,233
    He's doing the same thing on at least two other boards ....
    *** Disclaimer ***
    As I have no wish to toy with anybody's life, I suggest you take this and all other posts with a certain amount of skepticism. Carefully evaluate, and if necessary, research on your own any suggestions or advice you might pick up here, especially those from my posts, as I obviously haven't the skill and experience exhibited by some of the more illustrious and more successful members of this forum. I'm not responsible for anything I say, as I drank toxic water when young.
    5,318
    Quote Originally Posted by calweld View Post
    Make that maybe 102 other boards if it's the same user. Rather oddball posts...
    Dec 2005
    Lodi, CA
    1,233
    I agree, Pop, not quite off-topic, but the posts are meaningless just the same. Spammers are getting smarter, huh?
    *** Disclaimer ***
    5,318
    I like to keep my posts worthless and to the point.
    Anyway, DaveJeep, glad it was just a booger in the gas line and a reg.
