Results 1 to 10 of 10
    Nov 2007
    SW PA.
    501
    Another broken casting....
    Hey guys,
    Here's another broken casting that came in that was caused by another woman driver on her cell phone yadda...yadda...yadda instead of paying attention. This is a base/pedestal for a cast mailbox that is threaded at the top for the mailbox to be screwed down in place. Fortunately for my customer, the woman did stop to inform him of the damage & offered to pay for the repair. I finished it today & the customer was pleased with the outcome.
    I've been doing all casting repairs with the Cold Welding Cast w/MIG process that has resulted in 100% success so far. I used .030, 309L, 98/2(AR-CO2), at 80A for this job. The customer had both pieces lightly ground clean to get a good look at the break so all I had to do was wire wheel the metal clean & put a .045 bevel on both pieces. The break fit together quite nicely & I did a very small tack on opposite sides to hold. Then I ran a 1" bead on opposite sides. The casting was only luke warm to my bare hands after welding. I allowed to cool for 15 min. & did another (2) 1" beads, again on opposite sides & repeated this process with 15 min. intervals. The casting never got more than luke warm to the touch & NO TINKLING of the casting so I knew it was solid with no cracks. Hope this may help someone. Here's the pics.
    Denny
    Complete weld/mach./fab shop
    Mobile unit
    Jun 2006
    609
    nice job man
    Nick
    _____________________________
    Miller 252 Mig
    Miller Cricket XL Mig
    Millermatic 150 Mig
    Syncrowave 200 Tig
    Century 50 Amp Plasma
    2- O/A outfits
    Spot welder
    Jet Lathe and Mill
    Jet 7x12 horiz/vert bandsaw
    DeWalt Multi Cutter Metal Saw
    Electric Hydraulic vertical press
    CNC 60"x60" Plasma/Router table
    www.nixstuff.com
    www.youtube.com/watch?v=jTu7wicVCmQ
    Salem, Ohio
    1,094
    Cool
    Nice work...Bob
    Bob Wright, Grandson of Tee Nee Boat Trailer Founder
    Metal Master Fab
    Salem, Ohio
    Birthplace of the Silver & Deming Drill
    http://www.ceilingtrains.com/
    http://groups.yahoo.com/group/sawking/
    http://groups.yahoo.com/group/southbend10k/
    Austin TX
    4,861
    Quote Originally Posted by yorkiepap View Post
    Now that's a small bevel!
    Hobart HH 125EZ
    Nov 2007
    SW PA.
    501
    Hey Zrexxer,
    Yes, that would seem small, although, with a .045 bevel on each piece, the .090 "V" provides a really good start of the .030 wire & puddles quite nicely to flow into the joint. It has worked nicely on other applications as well. Sometimes, minimal works best.
    Denny
    Mobile unit
    Austin TX
    4,861
    Ahh I wondered about that... I thought you might have done something like I tend to do, like thinking 45º and typing .045.
    Hobart HH 125EZ
    Jun 2008
    Martinez CA
    1,572
    Wow another light pole guy.....hahahaha I repair the city's broken light poles all the time myself....BUT theirs are aluminum.......
    Dynasty 350
    Hobart Beta Mig 200
    Twenty seven Hammers
    Three Crow Bars
    Two English Springer Dogs
    A Big Rock
    Feb 2007
    raleigh, nc
    448
    I have a 1998 murray riding mower and the front axle assembly is cast and it broke in two and also has a crack about 4" long from the bottom to the top. I havent figured out what process (Stick, tig or braze) I am going to use to repair it being it will be under heavy stress.
    heres a pic of what it looks like
    http://www.quickieparts.com/murray-p...-assembly.html
    It sits in my house whispering to me "I want to be fixed" and I keep putting it off.
    I"ll post the prep and repair with some pics when I get the urge to tackle it.
    Miller trailblazer 301G
    Miller S22P12 feeder w/ss case
    K&K 300 amp 15' .035-.045 (Bernard)
    Miller HF-251D-1, Weldcraft AC torch pkg
    Hobart HH187
    Harris DLX STLWKR
    O/A & chemolene
    WARNING These stunts are performed either by professionals or under the supervision of professionals. I insist no one attempt, recreate, or re-enact any activities performed.
    Jun 2008
    Martinez CA
    1,572
    I have good results with Ni Rod Nickel 99 (Tig ) On cast iron. If it's cast steel just weld it with you mig or stick I guess.... I'm not a stick welder so maybe someone else can add to that....Good luck ...
    Dynasty 350
    Hobart Beta Mig 200
    Three Crow Bars
    A Big Rock
    Feb 2007
    raleigh, nc
    448
    Its definitely cast.
    I never tigged cast iron. Will it create a puddle on the cast and add the ni rod nickle as filler like regular tigging or will it melt the nickel to the cast iron and fill as in soldering?
    Hobart HH187
    Harris DLX STLWKR
    O/A & chemolene
