What equipment do you have? Nearly every manufacturer has a wbsite where you can get copies of the appropriate manuals.
Settings depend on a lot of things, like tip size, hose length, etc., but for welding, both fuel and OČ are the same (5 psi is a good place to start); for cutting, 5 psi on the fuel and 40 psi on the oxygen are good starting points.
As previusly stated, be sure you know what you are doing before you introduce fire to the equation.
