Results 1 to 8 of 8
    S.E. Wisconsin
    4,549
    #2 heating head ?
    Learning Babbitt puddling, they told me a #2 heating tip is the best for
    the work that we usually do. Said the supplyer only carries the Odd #'s now.
    After 2 days, I can see he is correct a #2 would be optimum.
    I'm not real up ta speed on O/A supplies / nomincature etc. etc.
    There's got to be still even numbers right??
    The whole world doen't just stop making a thing!
    I want to buy my own .... infact two tips, and my own set of cleaner-wires.
    Any clarity ot offer?
    Don't have time to research this for a few days.
    VG
    Nov 2008
    139
    Ages ago I used to Pour Babbit bearings, Got to puddle once or twice, it is tricky to do correct and get past NDT.
    look here for Victor
    https://www.mythermadyne.com/thc/en/...&catKey=601767
    I suspect this is what you are looking for
    but if no one carries them locally you are out of luck if in a hurry
    https://www.mythermadyne.com/thc/en/...2508false%2508
    5,318
    What brand/model torch? If you have a Victor or Smith, you can get tips from Cyberweld.
    Jan 2007
    Wisconsin
    331
    Yep need to know the torch brand and model. Number sizes mean squat without the other info.
    "Better Metalworking Through Research"
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Smith, Meco, Harris, Victor, Prest-o-lite, Marquette and even a Dillon O/A torch
    S.E. Wisconsin
    4,549
    Smith...model "natural" or some goofy name like that.
    I found a #1 that's been cleaned so often I could worry
    the 2nd cleaner-wire into it. Worked good.
    Babbitt is amazing stuff. Like'n this puddling stuff!
    vg
    S.E. Wisconsin
    4,549
    Oh by the way.........
    As long as I'm at it, I'm do'n it ambEdextrously.
    Left is fine, right I have the same motion limit that complicates my Tig.
    Can I bend the tip a little closer to 90 degrees
    as long as I stay back from the tip?
    VG
    5,318
    Why not call Smith customer service and ask? (605) 882-3200 7:30am - 4:30pm CST Monday - Friday
    Or email them - address is here http://www.smithequipment.com/contactus.html
    S.E. Wisconsin
    4,549
    Thanks.....too tired & ignner't to do dat much ReSearch'n.
    vg
