Results 1 to 2 of 2
    Mar 2009
    Out of my element...
    ...and no one else in the company can assist me.
    Since October, I have been designated as the test guinea pig - whipping boy, for our company to become certified/qualified in 2G and 3G for the latest ISO's out there for Gov't contracts using GMAW.
    I've been welding for 25+ years and this go 'round I've tested on all sorts of steel alloys from 8" coupons to 30" coupons that get x-rayed then, they go through the tensile tests.
    With all of that complete, this week I begin the aluminum portions - something I've never welded out of position - and I am required to use 3/64" ER5356 aluminum wire on 1/4" plate, set up for 3G with a 1/4" open root with a 1/4" backing plate of aluminum.
    The testing labs tell me that I cannot use my usual weaving pass as on steel, and have to drag it straight up at a minimum of 180 amps and 25 volts - maximum of 225 amps and 27 volts.
    The machine I am using has a wire speed control inside the feeder, outside of the feeder on the front, and on the gun itself that contols the previous two contols.
    I was able to get the parameters required, but I'll be danged if I can get the first two roots to look like something that you'd want to call a root.
    Does anyone in these forums know anything about the technique I should be using, as these 1/4" coupons have to pass x-ray and tensile?
    Feb 2009
    71
    You might try the local career training school welding instructor.Another help might be the pipefitters union in your area.Or the company that built the welder you are using.Good luck.
