OK. So here is the thing. For anyone who wants to know or anyone who cares.
Never buy an inverter style welder!
Now that I have looked at this in some depth, I cannot understand the stupidity in trying to get away with it for any length of time........Unless your design is absolutely bullet proof and you use only the best components, over engineering the s**t out of it from the get go.
Reason: Take 240v, (Australia) rectify it and drop it to 60v (DC) with the ability to draw 160Amps. This means disposing of 160v at 160 Amps....25000 watts.
No wonder they need two fans.....what they do is use a 'pulse width modulator'
just a fancy way to say they switch it on and off a few times per second and then just add up the ON bits and store it. (integration) so that the average voltage is now much less.
But switching 240v DC on and off at 160 amps takes quite a bit so they use 12 mosfets on a heatsink with a whole lot of filtering and smoothing just to get 60v DC at 160A.
****! a transformer is so much easier and more reliable. My old stick welder is 60v at 160A and it gets a bit hot but is dead reliable......all those little plug packs that power mobile-phones, intercoms, calculators, all run on the switch mode design instead of wire transformers...they have decided that the transformer is old fashioned and too environmentally unacceptable.......
Bl@@dy Greenies!
But I am having a rage....I will just pull this to bits for the parts and go back to my home made DC only TIG that cost me peanuts to build and goes like S**t out of a Shotgun!
Stay away from Chineese inverter cr@p! it is too complicated and unreliable QED!
Cheers.
