Howdy. First post...
I purchased the subect Hypertherm900 off of ebay a while back and would like to build a portable set-up. I will also be using a Ironman250 mig with the same generator..
My question is this - would a 10kw generator (single phase, constant 40A @ 240V, 50A surge) be adequate for most use? According to the specifications, the Hypertherm900 requires 47A @ 240V to reach the maximum cutting output of 55A.
Max for most of what I will be cutting is 3/16" aluminum and 1/4" steel. I will also be running an air compressor on the same generator, but I'm thinking (hoping?) that I could stop cutting when the compressor is running.
Here is the generator head I'm considering:
http://www.northerntool.com/webapp/w...6970_8795_8795
Here are the Hypertherm900 specs I found:
http://www.hypermax.org/Specs%20900.htm
Thanks in advance for all replies.
