The base is a HF small mover's dolly
So far so good...looks like it's open to future mods.
It also looks like an upside-down bar stool
Cheers,
John
There's (GASP!) WOOD on it!!!![]()
Arcin' and sparkin', Rocky D <><![]()
Hey Rocky,
Here's my plasma cart. Notice no wood.
At the back of the cart I mounted the combo coalescing filter and the desiccant dryer. These feed to the Hypertherm filter which is mounted to the 1250. What's not shown is the Binks (paint grade) hurricane filter which is mounted at the end of my hard piping and downstream of the regulator for the plasma supply.
I feed the system with 1/2" hose with 3/8" fittings. I think the 1/2' hose gives better flow than the standard 1/4" airhose.
SundownIII
Syncrowave 250DX, Tigrunner![]()
Dynasty 200 DX w/CM 3
MM 251 w/30 A SG![]()
HH 187 Mig![]()
Dialarc 250 w/HF 15-1
Hypertherm PM 1250 Plasma
Victor, Harris, and Smith O/A
Mil Mod 6370-21 Metal Cut Saw
Grizzly 6"x48" Belt Sander
Miller BWE and BWE Dig
Easy, Rocky...Sit down and take a whiff or two of arc fumes...Yeah, I saw that, and wondered if he'd slip past "The Inspectors"....I also thought it looked like an upside down bar stool!! I'm concerned that its height to width is quite high, so no heavy equipment should be placed on the top (tippy)...
Rocky,
Here along the coast in VA, it gets really humid in the summer months. Each filter serves a separate purpose. Also got a Motorgard (used to use with my PM600) that I can put in line if necessary. Don't think I'll need it though.
The Binks does a good job. Done a lot of painting with that filter and never had a problem with moisture in the air.
With plasma, the cleaner/dryer the air, the longer the consumable life. The 1250 is really good with consumables and I attribute some of that to the fact that it gets good air. It's a great machine and deserves to be "fed" correctly.
Anyone who does a bit of plasma cutting in the shop may want to take a look at the grate (in the .75" cut link) sitting on top of a 55 gal drum. I knocked that out in a couple hours one afternoon. The grates themselves were cut from 1/8" plate and are removable/replaceable as needed (due to cutting). An inch or so of water in the bottom of the drum makes cleanup a lot easier.
SundownIII
HH 187 Mig![]()
