I have trouble achieving an even weld and getting the aluminum to flow into and around the corner for inside corner welds. I end up with an uneven weld with a larger weld in the corner as shown in the attached pictures. I need to heat up the corner for a long time to get it to flow. Any tips or tricks would be appreciated.
Current: 160 amps
Frequency: 250 Hz
Tungsten: 3/32 Tri Mix
Balance: 70%
BC your inside corner welds always look so uniform. Anything that you can share on how to do this?
