Results 1 to 12 of 12
    Dec 2007
    Central Ohio
    124
    Electric Cord Types SO/SJ?
    I did some Google searching but I've run out of patience. What exactly is the difference between SO and SJ cord?
    Austin TX
    4,858
    SJ CORD DESCRIPTION:
    Stranded bare copper conductor, seperator, SBR Rubber or EPR insulation, suitable fillers, separator, thermoset jacket. -40C to +60C
    SJ CORD APPLICATIONS:
    SJ Cord is designed for use in portable tools and equipment, portable appliances, small motors and associated machinery.
    SJ CORD FEATURES:
    SJ Cord features good flexibility in low temperatures and SJ Cord is suitable for use in conditions where the cord is not subject to acid, grease, oil, or solvents.
    SO CORD and SOW CABLE DESCRIPTION:
    SO Cord and SOW Cable feature stranded bare copper conductor, separator, CPE Rubber or EPR insulation, suitable fillers, separator and CPE jacket. SO Cord and SOW Cable have a temperature range of -40C to + 60C.
    SO CORD and SOW CABLE APPLICATIONS:
    SO Cord and SOW Cable are designed for use in portable tools and equipment. SO Cord and SOW Cable may also be used for portable appliances, small motors and associated machinery.
    SO CORD and SOW CABLE FEATURES:
    SO Cord and SOW Cable feature excellent resistance to oil and moisture, good tensile strength, elongation and aging characteristics, high flexibility, excellent abrasion resistance. SOW Cable and SO Cord are water resistant, UL listed and CSA certified for indoor and outdoor use.
    Hobart HH 125EZ
    Jan 2003
    GA
    187
    SJ is rated for 300 Volts
    SO is rated for 600 Volts.
    Quote Originally Posted by BMB View Post
    That's really meaningless. In a shop/garage environment, junior vs. hard service is seldom, if ever, an issue.
    In any case, who gots a 600V service?
    Austin TX
    4,858
    The most important distinction I see off the bat from the information I posted is "SJ Cord is suitable for use in conditions where the cord is not subject to acid, grease, oil, or solvents." That IS important in a garage environment.
    Hobart HH 125EZ
    Dec 2007
    Central Ohio
    124
    Thanks for the info.
    I was buying some cord to setup a generator cord to hook up my new transfer switch. The factory cable with the generator (with the break out of 120 outlets) was SJ. I wanted 10-4 because I have a 30 amp rated switch but they were out. I only have a 20 amp rated generator (L14-20 outlet) so I ended up getting 12-4 so I could finish it up. I installed NM 10-3 with ground from the panel to the generator receptacle, so that's all kosher if/went I get a larger unit.
    Funny part was the power came back on last night. They had been saying it would be Saturday so it was a pleasant surprise.
    Los Angeles
    5,539
    Just so ya have a Bookmark if ya need it later
    http://www.interpower.com/ic/NA_Cable_Types.asp
    MM252
    MM211
    SO 2020 Bender
    Quote Originally Posted by Zrexxer View Post
    Yeah, but my old 10-3 100 foot SJ has been in a "garage" for all of its ten year life, and shows no degradation from getting dunked with acetone and engine oil and muriatic acid. It all depends on how severe the exposure is, I guess.
    If I was running a plating shop, I'd be more concerned, probably.
    11,592
    Certainly at home most there are not service above 300V but in industrial there may be, then SO is needed.
    Jan 2003
    GA
    187
    But it is a difference and when I was in electrical sales it was good to know.
    Oct 2007
    London Ontario
    290
    Quote Originally Posted by hankj View Post
    Not meaningless for me my work shop is wired for 600v 3 phase. I will have to check the temporary cord I am powering saws up with to make sure it is SO I guess.
    Apr 2004
    411
    I thought SJ used a copper clad stranded steel wires? Or is there a similar cord with similar designation? Somebody help me! Uncrichie.
