Results 1 to 9 of 9
    Dec 2007
    14
    Fan failure on EZ 125
    I bought a ez 125 on 12/27/07 and only did a couple beads to check it out after I bought it to try it out. I am a carperter and really don't have a reason to own a welder other to make up some brackets or fix a garden tractor and what not.
    Well this weekend I actually had a little project to do.....long story short...I put about 35-40 minutes on it and I heard a clunck and then it didn't sound right so I stopped and got out the manual.
    I thought I over heated so I let it sit, and sit ,and sit, tried the overload. Nothing.
    Come to find out when I took the the outer shell off it, the fan itself had actual come off the shaft that it is supposed to be on. When I put it back on I noticed it was split so it came right back off when I started it again.....
    Questions:
    Has anyone else had this happen?
    Should I drill it and pin it so the new one don't do the same thing or will this f- up the ballance?
    Where can I get the part?....I figure it's only a $5.00 part, nylon...but I don't like putting my credit card info on the web.
    Another question???? Does a welder have any kind of compasitor in it that holds a charge in it after you unplug it like a TV ?
    Thank for any input guys.
    Funny sidenote......I forgot all about getting "sunburn" from a welder....I work outside year round so I'm nicely tanned now with a bright red chest!
    Austin TX
    4,858
    EXACT same thing happened to me. Keith at Hobart sent me a new fan for it. See my thread at http://www.hobartwelders.com/weldtal...ad.php?t=29936 though for a possible temporary fix until you get the new one.
    Hobart HH 125EZ
    7,716
    Yeah, I remember that one...Hobart tech support is the best there is...they'll fix you up in a jiffy!
    Clark County, NV
    5,194
    Hobart will definitely fix you up. But if you're in a hurry, just about any appliance parts store will have a fan of the right size and for that shaft, just verify the rotation, too.
    Jun 2007
    lancaster,ohio
    175
    Talking
    If he puts the fan on backwards will the machine make cold instead of heat?
    Clark County, NV
    5,194
    No, but it has to be reversed if he brings it to the southern hemisphere...
    Dec 2007
    14
    Smile
    Thanks guys...I called today and they are sending me a replacement.
    Nobody answered my other question though, Is a welder completely dead once you unplug it?
    By the way, those last two post were real helpful!
    Aug 2008
    32
    Yes, its completely dead.
    HH125ez
    Airforce250ci
    AC BuzzBox
    Clark County, NV
    5,194
    Always give a machine at least 15 minutes if you don't know whether you are dealing with caps or not.
