Results 1 to 4 of 4
    Aug 2004
    Dearborn Heights, Michigan
    158
    Hobart Titan 8 combo welder / generator CC/CV 18hp kohler $400
    EDIT: SOLD for $400
    Well, I figured I should get my Hobart Titan 8 combo out of the garage and let it run for a while and change the oil and what not. I only use it to power my house when the power goes out and I havent ran it in a couple of years.
    Well I drained the old gas, added fresh gas and it started up but then after about 10 sec it started to smoke ( exhaust ) and then stopped running. After some messing around for a couple of min. I pulled a plug and it was soaked with fuel. I dried the plugs and put them back in and it started right up but then did the same thing and loaded up on fuel. Also I noticed fuel dripping from the bottom of the carb. SO, I think the float is stuck and flooding the plugs and also filling the carb. It never did this before and I don't want to mess with it.
    It has ac / dc , CC / CV
    18hp Kohler
    Located in Dearborn Heights, Michigan 48125
    braxx@wideopenwest.com
    Josh
    This pic was posted by a member here and mine looks a lot like it. I'll try to get actuall pic's
    Josh
    Lincoln ProMig140
    S.E. Wisconsin
    4,472
    Thumbs up You or a buy-er..........
    Will have an easy fix, sunken float (or stuck) is an easy fix.
    Nice price too, considering it doubles as a home-generator.
    Too far away for me.
    vg
    Oct 2007
    London Ontario
    290
    I sent you a private message regarding your welder.
    Aug 2004
    158
    Ya, I assumed a stuck float. I have 3 other generators and no need for it as a welder. Any how, it sold very quickly this morning ( after 2 guys argued over it )
    Josh
    Lincoln ProMig140
