Hi,
When putting together my stainless steel water tank I will need to put in some temporary supports to hold it all together which will then later be removed when the tank is finished.
Now what i'm wondering is will it be ok to use mild steel stock for this, welded with stainless steel wire. Reason being I dont have any stainless running around that I can use and cant justify the cost for something like this. I have plenty of mild steel pipe around that I can use.
I think it would be ok to use, but just thought i'd ask. Also is this the way it's done in the industry.
By the way it's 316 grade stainless.
