I have a Titan 8 Combo with a 20-HP Kohler that I am fixing up. As the new owner, I discovered it had ingested a small screw via the air cleaner intake that took out the #2 piston. I washed the engine innards out with a bug sprayer filled with kerosene, installed new pistons, rings, good used jugs and heads, and a new carb and it runs like almost new. I also repaired the idle speed controller and installed a 12 volt mechanical relay to drive the idle solenoid so it wouldn't fail ever again. It runs great but now I am worried about replacing the alternator brushes should they ever go bad and I wonder just who actually made the alternator. Did Hobart make it or were they supplied by Onan...??? Also, I saw a Hobart Titan Welder decorated with stickers of the Warner Brothers Tasmanian Devil holding a welding rod and torch. Where can I get some of these stickers...?
