    Mar 2008
    North Idaho
    5
    regulator question?
    Hey new here, i just bought a new HH 187 and the regulator says its for use with argon, does that mean i cant run Co2 through it??
    Thanks Ty
    Clark County, NV
    5,078
    You can run the argon/CO2 mixes through it, but you run a serious risk of freezing the regulator if you run 100% CO2 through it. I know; I froze two of them (in the Las Vegas summer) before I figured that out. Others have done it with no problems, so it's your choice if you want to risk it.
    You will need an adapter for CO2...I always used flowmeters, but I believe the OEM regulator can handle it. The freezing occurs when you have to high of a gas flow, or welding for long periods of time, and I think the atmospheric conditions play a part in it too. I was close to the ocean, where it's humid. I did freeze up a few times, but it never affected my welding. So I never worried about it. There are even heaters for them to prevent frosting, too, but I never used one.
    Mar 2008
    North Idaho
    5
    Thanks guys, i have ran co2 for years, and didnt remember it say that on my old hobart. i think im going to go for it and try. thanks again
    One more thing what do you think about running co2 vs mixed?
    i weld all diffrent thickness of metal, mainly jeep frames, axles, bumpers stuff like that.
    Clark County, NV
    5,078
    Quote Originally Posted by TWINTHER View Post
    You should find a million threads on that here.
    CO2 is great for general purpose. Much cheaper, lasts longer in the same size bottle, and almost as spatter-free until you get to really thick stuff.
    Argon mixes are more spatter-free through a greater power range, and allow you to weld thinner sheet metal.
