Results 1 to 4 of 4
    NYS
    72
    Torch Holder TIG
    Lincoln Square Wave TIG
    I fabricated this "torch holder" Kind of handy because at times there is no place to lay the torch down. Just 1/2" tubing, formed some brackets and bolted to the existing hole in the case. Works great and saves breaking the back cap.
    Re: Torch Holder TIG
    Yeah, I do that, too...I have hooks and even a rod holder on my machine.....we call "point-of-use" in my plant. Ergonomics, etc.
    The torch you have connected is what we use only for aluminum, and the other one you have there with the gas screen lens we use for most everything else.
    Here a picture of it.....Sycrowave 300 on the bottom and a XMT304 CC on the top. Hooks all over.
    Rocky D
    What is that below grinder switch, operating/safety instructions?
    I once saw shop that had them posted for everything. Vice, anvil, hammer, workbench, power machinery it all had safety/operating instructions posted nearby.
