Hello, i am new to this site and have a question on power wires for my new Hobart Tigwave 250. On the name plate it says that if you run it on 230 volts the unit needs 98 amps input for 250 amps output at 40% duty cycle so that would be a 100 amp service with number 2 wires coming from the outside service panel to the welder disconnect switch. I looked in the NEC code book and they say in article 630-11 that the supply conductors can be found by using the current values determined by multiplying the primary current in amperes given on the welder nameplate and the multiplier from the chart in the NEC code book. In my case my welder has a 40 % duty cycle and in the books chart under the duty cycle is the multiplier of .63 and the welders input amps of 98 amps so if i do the math it comes out to 61.74 amps at full power. The old setup i have in my shop is a 150 amp outside service from that i ran a number 6 wire over to a 100 amp sub panel, the number 6 wire has about a 70 foot run from the outside service panel to the sub panel in my shop and between the outside service panel to the service panel in my shop the number 6 wires are protected by a 60 amp fused disconnect. I only ran a number 6 wire when i put in the sub panel because at that time i though 60 amps would be more than enough to run the machines i have in my shop due to the fact that i am a one man shop and i can only run one machine at a time. Under my sub panel i have a 50 amp plug receptacle that i ran my old Miller Econotig from, that plug is protected by a 50 amp breaker. My question for all of you is do i need to run new number 2 wire over to my sub panel from my service panel and from that to a 100 amp service disconnect switch or is the information in the NEC code book right and the number 6 wire i already have installed enough to power the new welder or am i misunderstanding the information i am reading in the code book? Just a little more information the other machines in my shop are a 9X42 Bridgeport mill a 14X40 engine lathe, 8X28 mill drill, 5X6 Horz. bandsaw, 9X15 Vert. bandsaw, 6X48 beltsander, 12 inch disk sander, Darex endmill sharpener, Darex drill bit sharpener, 5 HP. 60 Gal. Horz. compresser, and the new Hobart 250 amp welder. I know what some of you are going to say, that is too many machines for only a 60 amp service but As i said before i am a one man shop and i only run one machine at a time, never two and up to now i have never had any problems because i try to do everything up to NEC code but i just want to be sure that with the new welder i dont have any now. I am open to any input you may wish to add but please NO FLAMES if you think i am doing something wrong just be nice and tell me how to do it right. Thank You
or run it smokin hot at 310 amps for 30 minutes at a time.
