I wonder what your preferences are in terms of welding and cutting tips positioning in relation to the handle valves. Do you position them in one plane so that the valves face the opposite hand when you weld or cut?
Where do you prefer the oxy cutting lever be: on the top or underneath the torch?
Where do you tend to grip the welding and cutting torches in relation to the handle valves: toward the tip of at the hose connectors?
Also, I'm thinking about adding a hose extension. I currently use 25' of 1/4" dual hose. Do you think using 3/16" extension at the torch end will make torch manipulation noticably easier? Do you think 25' extension with the smaller diameter hose will make any difference in terms of gas delivery (I don't think so, but would like to hear your opinion. I have Victor Superrange II medium duty setup).
Thank you for sharing your thoughts and experience!
