Results 1 to 15 of 23
Thread: Bullet Trap
    May 2007
    Kansas
    115
    Bullet Trap
    Anybody built or have a design for a decent bullet trap?
    I'm getting the urge to build one that will stop up to a .38 Special. I have a 30x50 outbuilding that would make a pretty good place to shoot provided that I can keep the bullets from exiting.
    Thanks.
    I just use a sheet of 3/16" steel set at a 45 angle behind the targets. The ricochet drops into a bed of sand.
    The hottest round I've ever fired at it was a .223, but it didn't penetrate. It handles all the pistol ammo anyone has fired at it, up to .44 mag.
    Mar 2005
    Rogers, Arkansas
    184
    Had one years ago we used in the basement. It would handle a 22 cal. but we used it for BB gun mostly, while in the basement. It was a simple box bottom filled with sand to catch the bullet. I would try about 8 inches of sand. The top ricochet steel plate was set in at 30 degree angle to ricochet the bullet down into the sand. It extended from the very bottom of the catch box to the top where the targets were hung. I would use at least 1/4" plate for the ricochet plate. Watch the place where the bullets hit and if it starts to stretch or bulge any, then replace it with a heaver plate.
    May 2007
    Kansas
    115
    Thanks.
    I have to relate the results of my first bullet 'trap', many years ago.
    I had just gotten a S&W K22 and was so anxious to try it out that I filled a cardboard box full of old phone books to use as a bullet stop and went to the basement to try it out. There was nothing down there to set the box on to get it anywhere near a decent height to shoot at, so....I took one of the wife's matched stools from the kitchen.
    It worked very well. I shot a few rounds at the cardboard box, and checked the back of it to make sure nothing was penetrating. Of course, shooting at 8-10" of phone books, one wouldn't expect at .22 to go all the way through.
    When I got finished, and took the box off the stool, I was aghast to see at least a dozen perforations in the leather cushion of the stool. None of the bullets had gone out the back, but quite a few had exited the bottom of the box and lodged in the seat of the stool.
    That was fun to explain.
    I have since used big logs, but that makes a mess and now that I've got a torch and welder.....everything is starting to look like a welding project. It's like the old saying, when you've got a hammer, everything starts to look like a nail.
    Aug 2007
    Central Texas
    239
    I think the best one I have seen is two plates angled together to make a narrow "v" shape with the open end pointed at the shooter. They don't actually touch at the "pointed" end but rather have a narrow gap for the bullet to pass through. Behind that is a round or octagon shaped "cylinder" that the bullets enter and bounce around in until they lose all their energy. Best part is, no sand or fiber to clean up (it all sprays when the bullets strike). It catches all the bullets in the tube, then you have a door on the end where you can empty it out. You could just good bullet traps and see what you come up with, then copy one of the pics.
    Contact me for any metal polishing needs you may have, my avatar is a pic of a standard, painted fire axe that I ground, sanded polished and buffed to a mirror finish.
    6,025
    I used to use a few old phone books to stop .22s when I shot in the basement as a kid. Looked the bullets up in the yellow pages, I did. But shooting ice cubes with the BB gun was actually more entertaining. CRACK! It was a little more work to clean up the room, though.
    I've always been intrigued by the snail type of bullet traps, though that's probably overkill for a .38.
    DialArc 250 (1974), Idealarc 250 (1971), SyncroWave 250 w/Coolmate 3, SP-175+, TA 161STL,
    Lincwelder AC180C (circa 1952), Victor & Smith's O/A, Dayton (Miller) spot welder, 1200 sq.ft. of garage filled with crap and a kid that can actually run the stuff +++
    Apr 2006
    Southern Illinois
    77
    Cool Bullet Traps
    We had a surveyor out for some land work and while he was here I had him and his sons over and check 2 angles for me. The first angle is from the back of my barn/pole shed over my wetland to the rise at the far side. 907.10. Straight East, I will have 100, 250, and 300 yds. So we are looking at 4 traps capeable for rifle calibers. I will also have to build a parallel fence to keep the cows from the line of sight/fire. Of course every thing will have to be cow proof so I can let them in to do the mowing for me. I am checking locally in on some 5 x 12 sheets of 1/2 steel. Its rusty but that will not matter except when welding,etc. More info as it develops.
    SEE YUW
    Salem, Ohio
    1,128
    Cool
    Here is one i made from 3/8" plate. I am going to build a thicker one since my .223 just went thru it...Bob
    http://www.millerwelds.com/education...8232#post18232
    Bob Wright, Grandson of Tee Nee Boat Trailer Founder
    Metal Master Fab
    Salem, Ohio
    Birthplace of the Silver & Deming Drill
    http://www.ceilingtrains.com/
    http://groups.yahoo.com/group/sawking/
    http://groups.yahoo.com/group/southbend10k/
    Dec 2004
    16
    Several years back I "hobbied" with a few ex-military shooting friends and we developed a rather neat targeting system - neat enough that it is patented.
    Essentially, it was more than a trap but it had a trap design in it. What we discovered is it took a minimum 17 degree angle to safely turn everything from a .17 air rifle to a .30-06 (the largest thing we tested). We often use an angle at 20 to 25 degrees depending on the round.
    As for plate, we were using a hardened steel (but not quite armor plate) grade at 5/8" or 3/4" thickness if I recall. We could get it from the metal suppliers but it was a special grade that I do not recall without looking through the design papers. The stuff did not dimple and pretty much destroyed the projectiles. We had looked at the sandwich traps but we needed a solid surface onto which we could project or image our targets. What we discovered was a trap contained at the base of the target plate that was roughly 8" deep and had synthetic batting in it trapped most of the fragments.
    Now the neat part. The target system is electronic. It has sensors mounted to the plate that, without going into all the details, essentially triangulate very accurately the point of impact and multiple impacts. That information is then transmitted real time to a laptop computer that shows each round in sequence, the measurements between shots, the timing between shots, group diameter and with a voice synthesizer would call the shots so that you did not have to come off the sights. It all grew out of shooting competition air rifles and watching the Swiss targeting system used in the Atlanta Olympics.
    Sorry if the answer went beyond the question.
    May 2007
    Kansas
    115
    It may have gone beyond the question, but that's OK! Keep going if you like.
    When you say 17 degrees, do you mean from horizontal? Sorry if that's a stupid question.
    Dec 2004
    16
    17 degrees tilted forward toward the shooter. We tested at various angles using initially a sand pit to figure out how much tilt we had to have (without loosing the ability to project target images) to get the round down rather than back at the shooter.
    If anyone is interested, here is the patent:
    http://www.google.com/patents?vid=USPAT6367800
    Jan 2008
    Valencia, PA
    14
    Armor plate
    If anyone is in the Pittsburgh area, the contractor that is refitting the Humvee's for IRAQ is in the area, and there are piles of 5/16 armor plate at the local junk yard. You can pick them up for scrape prices. Most pieces are are about 15" x 30".
    HH210
    Lincoln AC Stick
    O/A
    May 2008
    scrap 5/16 armor plate
    do you know the name of the scrap yard
    thanks
    Bulverde, tx.
    3,187
    Wow, that would be cool. Too bad it is too far away.
    I had considered building one for my shop...but when I found out I could be arrested for illegal firearm discharge, that kinda took the fun out of it.
    Don
    Go Spurs Go!!!!!!
    Salem, Ohio
    1,128
    Cool
    Quote Originally Posted by dda52 View Post
    Yup i have already had the knock on my door from shooting in my basement...Bob
    Metal Master Fab
    Salem, Ohio
