Results 1 to 15 of 16
    Oct 2007
    Stanfield, NC
    54
    Is there a tool to do this?
    Im trying to figure out how he does it? I would really like to be able to duplicate this. He some how makes his own 8" to 5" reducer? What type of machine would take a flat sheet of steel and mold it into a cone shape?
    I hope this photo shows up below?
    You can see on the bottom of the stack where it goes from 8" stack down to 5". I have been building 5" exhaust stacks along with 6 & 7" but have yet to be able to do the 8" he does due to the sheer size of the reducer needed.
    Oct 2007
    Stanfield, NC
    54
    I forgot to mention that the standard size of exhaust for the Y pipes & elbow that you can see in the pickup bed is 5" pipe.
    Sep 2005
    Davenport, Iowa
    824
    Take a looky at this......
    http://www.i-logic.com/conecalc.htm
    Oct 2007
    Stanfield, NC
    54
    That's a pretty neat tool. Now im just trying to figure out which dimension A & B etc. are.....seems handy!
    Oct 2007
    Stanfield, NC
    54
    That's a great tool. Im trying to figure out this cone dimensions if 5" pipe is around 15.5" (?)around & 8" pipe is 29" around I tried typing in those dimensions and it gave me a bogus cone.
    Is that template in inches?
    Oct 2007
    North Chili, N.Y.
    363
    Make a template out of paper first. When you get it the way you like it, then cut it out of steel. Paper is cheap, steel is not.
    5,332
    Austin TX
    4,861
    Quote Originally Posted by 9 LIVES View Post
    The model says diameter A and diameter B... not circumference.
    Hobart HH 125EZ
    Oct 2007
    Stanfield, NC
    54
    Gotcha...brain fart eh
    slow day for us lower edumicated folks
    Oct 2007
    Stanfield, NC
    54
    Does not seem to be that accurate. I typed in 5 & 8 for the diameter. Traced the pattern onto white construction paper. Taped it togather and measure my cone it was 4" X 7-1/4
    Oct 2007
    Stanfield, NC
    54
    Is this formula in inches? I have spent the last 2 days cutting out templates yet to find what #'s to punch in a funnel that is 8" at the bottom and 5" at the top. Seems simple but when you type those figure in the bare spaces it give you a funnel that is 3" at the top and 7" on the bottom.
    Mar 2006
    Taxsonville,Florida, U S A
    110
    Take your pipes to your local sheet metal shop with a dozen donuts in the morning and ask then for a hand
    Jim
    Millermatic 200
    Hobart Handler 120
    Black & Decker 14" chopsaw
    Dewalt 14" chopsaw
    And a serious big old Wells bandsaw
    F-550 pick-up
    5,332
    Maybe this will make more sense.
    In that cone calculator, are you entering diameter A as 8, diameter B as 5 and some nominal number for the height, say 6 inches and then clearing the default angle setting (make it blank)?
    May 2007
    The wet northwest
    622
    Looking at the picture on the calc page, it shows there's a section above and below the produced cone as 'extra trim stock'. Make sure it's blank. The diameters you are measuring would be narrower at the top and wider at the bottom to account for this. Measure off your correct height to double check this is the case.
    Just an observation.....
    I NEED MORE COWBELL!!!
    (ok, not really a 'Red'... )
    14" Milwaukee chopper
    Buffalo forge w/ blower
    Alot of pumps!
    san diego
    32
    You can do it on a metal lathe and not have a seem. This is a pretty simple spinning operation. You could actually probably get away doing it on a wood lathe. Here is a short little video of a guy spinning a piece:
    http://www.youtube.com/watch?v=DGszB...eature=related
