OK I read a post out here a while back and your ‘real’ welders gave some good pointers to this hobby welder about how to join two like pieces of metal at a T-joint. It was the one about Push vs. Pull when using a mig. (Just for those of you that will ask questions, in my case with gas.)
Next question:
Say I am trying to weld sheet or expanded steel to a piece of angle. You know on a cart or a workbench. I can get it done but it is nothing I want anyone to see. I have big globs (Not hot enough, too much wire speed?) and/or burn thru (too hot?) all over the place.
So I guess what I want to know is any special fabrication instruction as well as changes to settings on the welder. (Simple welder 1 thru 10 on both heat and wire speed.)
Do I start my bead on the thick material and just move the puddle to the thin?
What is the proper spacing for tack welds?
if it takes more than one 'whip' to get it to stick, so be it. The trick is to have a fairly 'liquid' puddle that you can whip over without getting the exp. so hot it vaporizes........
