Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Jul 2004
    Virginia
    416
    Welding a pipe onto my maul head
    I found a wood chopping maul head but now can't find a replacement hickory handle at any of my town's hardware stores. They have plenty of handles, just none come close to fitting my maul hole. Instead I'm thinking of welding a 1" pipe to it as a handle instead. Has anybody done this? Will 1" pipe stand up to the heavy wood chopping chores? Will it vibrate like crazy?
    May 2005
    Richmond, Virginia
    5,315
    Where are you in Virginia? I'm near Richmond. I have a few small hickory trees in the yard, and you can have one if you need it.
    If things are close but just a little beyond where your replacement handles can fit by being wedged, just get a couple of wedges and some poly glue and build it up. It really seems to stick well and fills gaps so that you don't get so much loosening from moisture changes throughout the year.
    DialArc 250
    SyncroWave 250 w/Coolmate 3
    SP-175+
    TA 161STL
    Lincwelder AC180C circa 1950
    Victor & Smith's O/A
    Dayton (Miller) spot welder
    1200 sq.ft. of garage filled with crap
    A kid that can actually run the stuff +++
    Jul 2004
    Virginia
    416
    Thanks for the offer!
    Unfortunately the handles I have seen aren't even close.
    Mar 2006
    Taxsonville,Florida, U S A
    110
    As long as your thinking about a 1" pipe, how about a 1" solid steel rod. It will be bullet proof that way and if you want a thicker handle just weld the pipe to that
    Millermatic 200
    Hobart Handler 120
    Black & Decker 14" chopsaw
    Dewalt 14" chopsaw
    And a serious big old Wells bandsaw
    F-550 pick-up
    Jul 2004
    Virginia
    416
    I thought of solid since I have a lot of thick rebar, but I think it might add more weight than desired.
    Feb 2004
    Bulverde, tx.
    3,178
    Yes, it is gonna vibrate like crazy. I used a sledge that someone did that to and it was the pits. I wouldn't do it. Have you looked online for them? Try these guys. Sometimes they have handles no one else has. www.bontool.com
    Don
    Go Spurs Go!!!!!!
    May 2005
    Richmond, Virginia
    5,315
    Can you adapt a pick handle? Is an "axe eye" maul?
    Ace Hardware sells a lot of different mauls. I note that many have a part number for a replacement handle. Some of those list the eye dimensions.
    DialArc 250
    SP-175+
    TA 161STL
    Sep 2007
    IL (St. Louis)
    228
    We got a guy at a local flea market that sells homemade wood handles. Maybe there is someone in your area that does that.
    Or you could just cough up the $20 and buy a new one with a fiberglass handle.
    Robert
    Snap-on (Century) 110 Mig
    Ridgid Chop Saw
    Makita 4" Grinder
    Quite a collection of scrap
    Functional Stuff is painted, my art rusts.
    The greatest lesson in life is to know that even fools are right sometimes. - Winston Chruchill
    May 2007
    The wet northwest
    622
    Heck yeah I've done it! I'm a po' kuntree boy! We wrapped duct tape around the handle at first but the tape got wet (Pacific NW, what can I do?) and gradually worked it's way off. So next we used a pipe insulation that was adhesive on the inside. Worked like a charm from then on. Dunno where the pipe insulation came from, didn't really care at the time. Sucker lasted forever.
    BTW: Is that the 'Tony Clifton' from Andy Kaufman fame????
    I NEED MORE COWBELL!!!
    'Red' Powcon 300ST (no torch yet)
    (ok, not really a 'Red'... )
    'Blue' Miller 35 (older than me and runs great), Thunderbolt AC arc (ditto)
    'Craftsman' AC arc (who made this originally?)
    O/A x 2 (both smaller than I'd like)
    14" Milwaukee chopper
    20t HF press (crap, but works)
    Buffalo forge w/ blower
    Alot of pumps!
    "All of us know more than any of us."- TexHand
    S. W. Missouri
    78
    I have one like this, have had it for 10 years and can't tear it up. It's all steel.
    Oct 2007
    Terrell, TX
    44
    I've used plenty of splitting mauls with pipe handles, whether homemade or store bought and never looked back at a wooden one. Splitting pine knots all day a wood handle WILL break
    Apr 2006
    Pennsylvania
    61
    The Monster Mauls were great, they would split anything. I did have a pipe handle break off one, didn't have a welder back then. Ha, I probably still have it somewhere, I might have to try to fix it!
    But I do remember days of sore shoulders after splitting wood all weekend. I think the vibration is a lot worse with the metal handles and I paid for it. But, wow, they DO split wood!!
    Why does everything have to be a compromise
    Dec 2007
    11
    Maul Handle
    Don't weld a pipe or a solid bar to it as a handle (although the pipe would be the better choice b/c it cuts down on vibrations. But both will definitely vibe bad). Just look harder for a wood handle for it. Will work out better in the long run.
    Feb 2007
    raleigh, nc
    448
    Go to your local hardware and buy a fiberglass handled maul (see pic file)and use your maul head that u have no handle for, to use as a starter
    Dec 2007
    Dallas,Tx
    15
    Quote Originally Posted by tonyclifton View Post
    i make ALL my own hammers.
    no one in the shop wants to use my hammers
