    Dec 2007
    7
    Wiring for a Hobart 187...
    I'm getting ready to install a NEMA 6-50R receptacle for a 187 that I'm buying and after reading the instructions in the manual, I just need to confirm something.
    It appears that the 6-50R has a place for a neutral wire but that this isn't needed because this is a straight 240 outlet and not 120/240. So I should just connect the two hot wires and the ground, leaving the neutral connector in the receptacle empty, right?
    Thanks for the help. When it comes to wiring, I like to make absolutely sure I know what I'm doing...
    Los Angeles
    5,485
    There is no connection point for a Neutral on a 6-50R-
    Did you get the correct receptacle?
    http://frentzandsons.com/Hardware%20...o.htm#50%20Amp.
    MM252
    MM211
    SO 2020 Bender
    Dec 2007
    7
    Thanks for the clarification...
    The wiring book I have has a wiring diagram for a 120/240v range next to a picture of a 6-50R, making me assume it was a 3 wire+ground receptacle.
    I'm feeling like I won't burn my house down now...
    Kyle
    Nov 2007
    Port Rowan, Ontario, Canada
    107
    I use a range receptacle seen here with a 50' 4c8ga extension cord plugged into it. The cord is coiled up under the range. The range is used for pre-heat and powder coating.
    I use a range cord & plug with a welding machine receptacle, as an adaptor for the welding machine.
    Miller XMT-300 w/S-64.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter
    Miller PC-300 and Optima pulsers
    Aug 2006
    Iowa
    466
    Quote Originally Posted by wyomingclimber View Post
    Kyle
    I don't believe welders have a use for the white / neutral / grounded conductor, only the green/bare wire needs connected to the earth / metal grounding point. DO NOT tie the white and green together!! BG
    Retired...
    Master Electrician
    Journeyman Refrigeration Pipefitter
    Semi-pro/Hobby Welder
    Miller MaxStar150 TIG/Stick Inverter
    Miller MM175 MIG
    Victor Oxy/Acetylene
    EMCO Maximat - Super 11 Lathe
    Grizzly X3 Mill
