Results 1 to 15 of 17
Thread: material lift
    Aug 2003
    Manitoba
    7
    material lift
    Here is a little project I just completed on Friday. Still need to prep and paint, but it I'm impressed with how it works. I plan on using it to lift 500 lb heatpump units onto stands up to 7', looks like it should work like a charm.
    Aug 2003
    Manitoba
    7
    pic 2
    Aug 2003
    Manitoba
    7
    pic 3
    Aug 2003
    Manitoba
    7
    pic 4
    Aug 2003
    Manitoba
    7
    pic 5
    Aug 2003
    MA
    297
    Looks nice. How much weight have you tried on it? What did you use for the crank? It looks like the same type as a boat trailer crank.
    axehind
    11,275
    Looks great to me,, how do the small wheels work with load on them or dont you have to move it loaded?
    Houston, Texas
    3,683
    Sberry, I have used a commercial version. Can't remember what it was called, High Boy or something like that. They rolled fine with a reasonable load. We used them to install roof A/C units on RVs.
    Aug 2003
    13
    Hi, what alloy did you fabricate the forks from? These can be very troublesome, the 90 is very highly stressed.
    Linc
    Aug 2003
    13
    Please pardon me, I forgot to tell you what a nice workmanlike lift you have built. Looks great.
    Linc
    Ga.
    610
    Nice Lift
    Very nice looking lift. What keeps the forks from moving away from the frame? I guess weight on the forks keeps it from moving forward. Have you tried it out yet? How much weight can you put on it? We used to have a commercial bought one sort of like it to unload big cast iron steam valves,pop off valves , and water pressure reducers. I believe it was rated at 1500 lbs. Nice Job!David
    Ga.
    610
    See clearly now
    Oh ,I see from pic 3 it looks like channel. I thought it was square . Good pictures
    Aug 2003
    nova scotia, canada
    255
    cool. nice looking job, but have you given any thought to putting a couple x-braces on the back side..... wouldn't want it to lay over sideways with a load on it.....
    just my $0.02. canadian$ at that :P
    crazy redneck bluenoser
    Southern California
    706
    Very nice design and build.
    If you are lifting 500#, I would test it with 750-1000# (of scrap) just in case. Be "poor form" to drop a new heat pump.
    Bob
    Aug 2003
    Manitoba
    7
    As far as testing I haven't gotten to far, lifted a 45 gallon drum of methanol with no problems so I guess we'll see what else it can do first. One of my "competitors" just rolled a 30 ton heat/cool unit off the back of a 5 ton truck onto the tarmac, to the tune of $28,000, he he he! So yes, I'll be careful not to damage my merchandise or my reputation.
    Thanks for the reply's and your opinions guy's, that's why I posted.
