Results 1 to 7 of 7
    Feb 2006
    9
    another wire feed problem?
    I have a Hobart handler 175 mig i bought about 4 years ago or so. I am a total novice, not even using gas yet...lol. I used it very little. One day i went to use it , turned it on, it powered up, but did not feed any wire. I checked everything(tip too) and it wouldn't work. I opened the door and fiddled with it. Not for sure what is going on. I admit, i didn't take the greatest care of it in hind sight. Meaning.....it sat on the floor in the corner, and got a little dusty. I have read something since about how you have to keep them clean inside and out...my bad. Can that cause a problem? I really only used it around 20 times...but of course, the warranty is long gone i believe. There is 2 welder service centers fairly close...but i'm affraid when i take it, they are going to say it's hundreds of dollers to fix..ouch! any help or ideas and i would gladly be in debt...you know what i mean...lol!
    May 2007
    The wet northwest
    622
    You're going to have to be more specific. The drive motor runs? The machine contactor engages? What do you mean by 'fiddled with it'? What have you tried / adjusted?
    I NEED MORE COWBELL!!!
    (ok, not really a 'Red'... )
    14" Milwaukee chopper
    Buffalo forge w/ blower
    Alot of pumps!
    5,204
    Do you have the voltage selector switch set to the purge/fan only selection? If so, the unit doesn't feed wire at this setting.
    PM 180C
    Feb 2006
    9
    Well, it's been awhile, but here is what i remember. The switch wasn't on purge. When i turn it on, i believe there is a fan that starts up. The motor that turns the roll of wire doesn't do anything or make any sounds. What i meant by "fiddling around" was more looking for unusual things...like burnt things...With such little use i just wasn't for sure what i could have done to cause this problem..unless maybe keeping it up off the floor on a cart or shelf...away from dust and dirt.
    Feb 2006
    9
    I did the search on the board and noticed the PTC 1 being talked about several times. I'll try the jumper and see. Oh my god, i would kick myself if that is all that is wrong. I have not been able to use it for a year or so...
    Oct 2006
    211
    Be sure the voltage switch is not between settings. It must click into a detent before motor will run. Is there any sound when you pull the trigger, a click or hum ? If not then check the torch trigger leads.
    O.F.
    Feb 2006
    9
    Yeah, i know the voltage knob was okay. The torch leads are a differant story..lol. When i was trying to find the problem, i took appart the nozzle to check the leads...and some how, broke one of the connector leads in half. I never did crimp on a new connector...yet.
