Hello: I've been lurking on the list for some time and am posting in hopes of getting some instruction. I've searched the archives of other metal artist forums and haven't found quite what I'm looking for, so please forgive me if this has been repeated at some point in the past as I don't get to read everyday.
I've finally arrived at the point in my artistry that I'm no longer happy with just painting my plasma cut-outs flat black. I'm looking to step into the world of color and try some experimentation with flame painting. I'm working with .088 hot roll sheet and after cutting out I knock the mill scale off with a flap disc down to bare, shiny steel. Using my brazing tip and working very slowly and patiently I can start to see the bare metal darken into maybe a light brown, and then blue then the blue will turn sort-of a grey-silver color if I overheat it. Buff it back out and go again, so far so good.
My question is how do I produce the variety of colors I've seen on projects on the list. Golds, yellows, coppers, deep-rich blues and reds. I know some folks use copper sheet and some use stainless, but I'm using mild hot roll carbon steel at this point. Seems I remember seeing something about painting the metal with a borax solution before heating...? Is there a trick to treating the metal that helps bring out the variety of colors? I would truly appreciate any feedback you can give me...I'm really excited to learn this technique. Thank you !!!
Ronnie Lyons
Meridian, ID
cog4150@hotmail.com
