Results 1 to 15 of 20
    Sep 2007
    11
    What advantages to a welding generator
    I am planning to get a generator for various uses but will probably use it to power my Miller Passport and Dynasty 200 at some point. What are the advantages of choosing something like a Miller Bluestar 185 DX over a equally rated generator from someplace like Home Depot?
    I can think of a few.
    No need for an adapter plug
    Higher resale value (not that I ever sell anything)
    Miller is a pretty colour (yeah, I know....You don't have to start)
    It can stick weld on its own
    Are these things worth $500-800 extra?
    Nov 2004
    Glenside PA.
    138
    Just make sure the generator can handle the peak amps. I would prefer the generator and dynasty over a bobcat just so I dont have to run a generator in my garage when i want to weld. With a big enough generator you can MIG TIG STICK & plasma cut with it. My$.02
    11,282
    There are a couple advantages with this type of unit. One big one is that it can be directly used as a welding unit, is rugged and quality compared to the avg generjunker from a box store. The welding units are normally dependable with a fairly long reliable service life. I got a 210A simple single cyl machine with lots of gen poop I paid 1600 for 25 yrs ago has never missed a beat, new ones still dont cost much more than that and are better than ever.
    11,282
    Are they worth the extra? Yes. A quality genset costs that much anyway and it don't weld. This would be a machine that the avg handyman/homeowner/ even some small business would never have to replace with regular use and common care.
    Another thing to consider there is great support compared to a generic junker, whole company that does nothing but develop, test, support with lots of common owners of these machines.
    Sep 2007
    4
    its too bad that Hobart doesnt make a good welder/generator.
    www.discusswelding.com - The Welding Forum. Just welding talk and nothing else.
    150
    I bought a Bluestar DX 145. There is a duty cycle difference between the HD/Lowes type generators and the Miller units. I compared the engines and found that the Kohler Pro 10 was rated for longer runs. I use the unit primarily for residential power backup. The engine maker's websites should be helpful. I assumed that Miller exceeded the engine durability ratings in their generators.
    Sep 2007
    Lake Of the Ozarks MO
    169
    I can't imagine life without my Bobcat and with that said I feel like it just does have enuff amps/watts to keep me happy.
    I'm not sure if a Bluestar has enuff power to run a 200 Dynasty at full power?
    What is the max on that unit anyhow?
    Miller Dynasty 700...oh yea baby!
    MM 350P PULSE SPRAYIN' MONSTER
    Miller Bobcat 225 NT
    Miller Dynasty 200 DX
    Miller WC-115-A
    Miller 30-A spoolgun
    Airco 300 Heliwelder (465 amp and made by Miller)
    Miller Spectrum 300
    Lincoln SP-135-Plus (down the road now)
    Aug 2007
    Northern central Pennsylvania
    201
    I was looking for a Miller Bobcat or Lincoln Ranger For portable work and residential power. I stumbled on to an older Hobart G-3010 for a third of the cost (and 4X the weight) The old Chrysler 225 slant 6 will cruise along at 1,800 rpm using scant more gas that a Bobcat cranking at 3,600 RPM. The Hobart has a 100% duty cycle. And as one older welder told me "if there were a way to hook drawbars of that old Hobart and a new Bobcat, the Bobcat would end up a molten puddle". I really like the idea of the Hobart running so much quieter that a Bobcat or Ranger. Not a big fan of continuous loud noise anymore.
    Quote Originally Posted by discusswelding View Post
    They do. It's called a Champion.
    Quote Originally Posted by Woof View Post
    Aside from the fact that it is a stand-alone welder, the power is much "cleaner" than the made-for-the-bigbox-store machines.
    Mar 2007
    Eastern Ontario
    165
    Couple of other comments.
    Electric Start - it was a must for me - as soon as you look for electric start in the big box gens you end up pretty close to the Miller price.
    Noise - If you move up a bit more you can get an enclosed welder generator to drop the noise level. Getting the same in a big box generator will cost you plenty.
    Parts and Support - Miller will be there for you.
    Cool Factor - all your friends will be envious.
    Note that there are some good generators coming available these days in the same price range. I was looking at a fully enclosed Kipor Diesel the other day that looked like a decent unit for ~$2K. And some of the auto switchover standby units are pretty slick, although they mostly run on propane or natural gas. If all you want is a home backup system - there is a lot to be said for a permanent installation and auto-switching that doesn't need a second thought - but for more general use and flexibility the welder gen was the way I went.
    May 2007
    The wet northwest
    622
    For a generator- the Millers will eat the box store generators in the long run. They're just built that way.
    For a welder- you don't get the versatility vs. the multiple units for process variety and use in-doors. Unless you drop the big bucks....
    You get what you pay for. A good long lasting generator will cost alot of money too! I wouldn't want to put my trust in a cheap generator with my Mig or Tig risking circuit boards to dirty power. Are you going to use the generator year round for other purposes or just as a 'welding power supply'?
    I use my welder more than I can come up with uses for a generator, let alone a generator of the size it would take to run one of my welders. I like using my welder in my shop too..........where it's warm........and it's easier to hear the football game on the radio...........
    I NEED MORE COWBELL!!!
    (ok, not really a 'Red'... )
    14" Milwaukee chopper
    Buffalo forge w/ blower
    Alot of pumps!
    11,282
    A good amount of the worlds portable welding work is done with stick electrodes. The equipment needed is simple, as one said, cant imagine life without his Bobcat. I agree, some rods and leads and you good to go. The avg guy would have a hard time wearing one out. Could run it for months if needed for power.
    Dec 2006
    Huntsville, Alabama
    74
    Hmmmm ! ! ! seems to me my Hobart Champ 10K works great, not had a minutes trouble, purrrrrssss like a kitten, welds very well.... runs ac equipment as well.... just can't find a reason to get something else. since it ain't broke i can't see fixing something that ain't broke...
    Mike
    HH 210
    Champion 10K
    Lincoln 225 AC
    Farm hand 115
    Victor Journeyman
    New Toys coming . . .
    Oct 2002
    wright city, mo.
    230
    what advantages to a welding generator
    HELLO TO ALL,
    the millers BOBCAT 250 is 100% duty cycle.
    hobart makes a machine that looks the same,
    but it is not 100% duty cycle. so if you are in
    the market for a machine, look for one that has
    the higher duty cycle. as for the price, yes they
    are high, but if you hagle with the dealer, you can
    get some extra things with the machine.
    wlbrown
