    Sep 2007
    Question Welding of Zn-22%wt.Al alloy plates,HELP!
    I am a university student. I am doing a final year project about welding of two identical Zn-22%wt.Al alloy plates. After using the Nd -YAG laser, the welded area lost the superplastcity. the objective is to weld the two identical plates while the superplastcity of the whole plastes can be retained ( including the welded area). I proposed another method, it is friction stir welding (solid phase welding) however, there is no such facilties for friction welding. there are only laser welding and arc welding machines. I would like to use the plasma arc welding or TIG. But I am afraid that the high temperature will vaporise all the Zn inside. Can you give me some comments to me on this issue? I am very frustrated.Thanks!
    Mar 2007
    south georgia
    47
    Red face this ones for imagineer!!!!!!!!!!
    WHOOSH!!! it parted my doo!(over my head) but I'm only one degree in metallurgy away from understanding the calibre of this conundrum
    tigamajig79
    Dec 2005
    322
    Hi lilunpan,
    I certainly cannot give you the answer. However, let me ask a couple of questions which stimulate some thought in the right direction...
    How is this alloy manufactured and/or treated to give it the superplastcity properties which you desire?
    Can something from the above processes be used as a post-welding treatment to restore the superplastcity properties?
    For example - if the material is heated to a certain temperature then quenched you might weld two pieces then heat and quench them as was done to the original material.
    Regards,
    Ken
    I don't know of any aluminum alloy with such a high zinc content...what is this material used for?
    Is brazing and option...or Electron Beam, perhaps?
    5,332
    Is this a Zinc alloy with 22% aluminum, or what? Something like this? http://stinet.dtic.mil/oai/oai?&verb...fier=AD0475357
