Results 1 to 15 of 28
Thread: Phase Question
    Sep 2007
    8
    Phase Question
    I just purchased a:
    Hobart TR-300 AC/DC Welding Machine Model TR4-300
    The info. plate on the front of the machine describes it as a 1 phase.
    The wiring diagram inside has instructions for changing the wiring for assorted input voltages
    volts: 208/230/460/575 these are 3 phase voltages.
    There are only 2 hot line input connections and a ground.
    What is this all about.
    I only have single phase electrical and am beginning to worry.
    Do I wire for 230 and run it with 240 single phase or am I euchred.
    Why does the plate say 1 phase.
    11,282
    Those voltages can also be had in single phase but hook it for 230 and you are good to go.
    May 2007
    The wet northwest
    622
    If it's like my machine (different manufacturer, different machine) you wire it for the 3-phase version of the correct voltage but only use 2 of the 3 power leads for single phase. Is there really no mention of it in the manual?
    I NEED MORE COWBELL!!!
    (ok, not really a 'Red'... )
    14" Milwaukee chopper
    Buffalo forge w/ blower
    Alot of pumps!
    Jan 2005
    Ludington,Michigan
    449
    The plant where I retired ran all of their single phase TM400 welders in the 1970s and earlier on 480 volt 1-phase.
    tooldude56
    Lincoln Square Wave Tig 255
    DC600/LN7
    XMT 304/64 feeder W/ digitals
    Esab PCM-875 plasma
    2 -Oxweld O/A ,W-17/CW-23 torches,R-77 2 stg reg.
    new Clausing Metosa SM1560VS Smart lathe CNC/Manual
    Wells index 12x48 mod. 847 vertical 3HP. mill,3 axis DRO,3 axis PF.,Maxi-torque-rite PDB.
    Dake #3 arbor press
    Kalamazoo H9AW hor. metal saw
    16" Kolley vert. metal saw,
    Trinco 36" blast cabinet with collecter
    All Snapon
    huge Summit vert. bandsaw
    6x18 Reid Rollerway surface grinder
    Sep 2007
    8
    Sberry Sberry Makes this sound simple.
    Some Creep you refer to splitting off two hots from a three phase supply.
    I don't have a three phase.
    Two hots from three would still give me two wave cycles rather than one @ 60htz.
    Sadly used equipment sometimes comes without a manual.
    11,282
    I wire the lights for a ball field 480 single. The runs to the outfield are so long the higher voltages make sense.
    May 2007
    The wet northwest
    622
    Quote Originally Posted by Dan Pro View Post
    Ah, no manual.
    Yes, I don't have 3 phase either. My machine works configured for 3 phase but uses 2 of the 3 leads for single phase power. Not splitting off 2 of the 3 hots, using the wiring configuration of the machine intended for 3 phase in the dual capacity of single phase operation. Like I said, different machine, different manufacturer. If yours doesn't do it, disregard the suggestion.
    Alot of pumps!
    Jan 2007
    21
    Not that I have an answer for your question, but if you were to use 2 hots from a 3-phase system, you would indeed end up with one waveform at 60 hz.... adding 2 sine waves of the same frequency always results in 1 sine wave at that same frequency, regardless of the phase shift.
    The only thing that changes on the end product, based on the relative phase of the 2 component waves, is the amplitude.
    There's my electrical engineering lesson of the day
    - John
    Sep 2007
    8
    Creep
    I misunderstood I hope your right it sounds promising.
    John
    I am under the impression that the waves peak and fall at different times giving a more even and consistent supply.
    May 2007
    The wet northwest
    622
    I didn't really word it correctly in my first response. I re-read what I wrote and it's pretty confusing how I worded it.
    In the few years I rebuilt welders I never came across or even heard of wiring done this way. I bought a welder and found it had this funky configuration of wiring it's terminal board for 3 phase but using 2 of the 3 leads (2 specific leads, not just any pair) and hooking it up single phase. I'd recommend doing a web search for a manual on that machine. Maybe there's a manual out there that can be had for free.
    EDIT: Hey! It's a HOBART!! Isn't there a manual available through this site??
    Alot of pumps!
    Sep 2007
    8
    I looked at the owners manual section but this machine is to old.
    I think it was made in the mid 70's
    Jan 2007
    21
    your 'peak and fall' explanation is right for using all 3 phases; with single phase it's just one sine wave as you know.
    (In one version of 3-phase): if you use one phase and neutral, you get 120.
    If you use any 2 of the 'hot' phases, you get 208. That's probably where the 208 comes from.
    That's if each of the 3 phases are 120. I don't know what 'standard' 3-phase systems are.
    In general though, with 3 phase, the phase-to-phase voltage (i.e. using 2 hots) is 1.73 times the phase-to-neutral voltage.
    more confusion !
    - John
    Sep 2007
    8
    Thanks John
    Sounds like I should use the 208 wiring option.
    11,282
    A little too much thought can be a bad thing on occasion, if this is a single phase machine then use the 230 option.
    Sep 2007
    Westchester Cty, N.Y.
    161
    K.I.S.S......Cary's right! Dont make it complicated. Standard utility is: 208volt 3phase...240volt single phase. Use the 230volt connections. Hook it up and have fun!
