Originally Posted by
Hotfoot
Well, I'm about to order a Bi Metal Blade for my Kalamazoo saw. It takes a 7'5" , 1/2" wide blade .025" thick. I go to ENCO, where I have been buying Morse Bi Metals for my HF saw, but they do not have a Morse in that size. The "Aggressor" Matrix II Bi Metal they list for mine only comes in a 10/14 variable tooth in .025 thick. I can go .020 10 tooth, or .035 10 or 14 tooth. I have never run a vari- tooth blade.
Should I go for a different blade thickness to stay with a 10 tooth (my usual)? Go with the Vari-ttoth and stay with my .025 thickness? Or...go up in thickness to a .035, or down to .025.
They did not have Starrett Bi Metal in my size, either...
Hands down...vari-tooth... IMHO
When I had small saws like years,years ago,the 10/14 vari-tooth is all that I used and they were great.Now I have a large Kalamazoo H9AW that use a 1" wide x .035" thick x 130 1/2" blade and switch back and forth between a 5-8 blade or a 6-10 blade for heavy solids,depending on thickness and an 8-12 for thin stuff,with no problems at all.I would never stray from the thickness that is reccomended by the saw manufacturer,because in my experience,you would just be asking for trouble.In the plant,we used a 1-1/4" wide blade in our big fully automatic marvel saws and used a 4-6 blade for the bulk of our sawing,with no problems.You will find that the larger the mass of the blade,the less problems you will have with it,even when sawing thin matereals.The larger blades will track better,keep cool better and are just generaly more durable and with the price tag on these larger blade,you will tend to be much more carefull with it.I have just purchased a cold saw,but plan on going to a 1-1/4" blade in a semi-automatic version,for my next band saw purchase.
tooldude56
Lincoln Square Wave Tig 255
DC600/LN7
XMT 304/64 feeder W/ digitals
Esab PCM-875 plasma
2 -Oxweld O/A ,W-17/CW-23 torches,R-77 2 stg reg.
new Clausing Metosa SM1560VS Smart lathe CNC/Manual
Wells index 12x48 mod. 847 vertical 3HP. mill,3 axis DRO,3 axis PF.,Maxi-torque-rite PDB.
Dake #3 arbor press
Kalamazoo H9AW hor. metal saw
16" Kolley vert. metal saw,
Trinco 36" blast cabinet with collecter
All Snapon
huge Summit vert. bandsaw
6x18 Reid Rollerway surface grinder
