Metal-work at it's Finest !
http://www.youtube.com/watch?v=7wsIKMncpLY
I could mezmarise for hours clicking from one to the next !!
Phil
Phil
In the beginning, the Earth was without form, and void.
When one picks up some wood or metal or stone and shapes it into something usefull
... I beleive that it has to be a deliberate effort to disavow a creator.
As you work these, and join them, you feel the force and the will of He
who formed and shaped the very resorces that you now add your will and force to.
Further one surely can know when your will and force is not aligned with His.
Interesting! I saw a museum-type display of Japanese swords one time at Texas A & M in the student center. Some were complete, some were just blades. Awesome. True devotion to the craft.
DialArc 250
SyncroWave 250 w/Coolmate 3
SP-175+
TA 161STL
Lincwelder AC180C circa 1950
Victor & Smith's O/A
Dayton (Miller) spot welder
1200 sq.ft. of garage filled with crap
A kid that can actually run the stuff +++
zzzzzzzzzzzzzzzz
What was interesting to me was how the magic of the sword worked against the bullets. The edge, which is harder than a bad girl's heart btw, held it's own. It didn't break until the bullets had chipped away the hardened edge and reached the softer steel which gives the sword it's ability to survive repeated uses. Thanks for the link.
Don't bring a knife to a gunfight.![]()
Hobart Betamig II
Hobart Betamig 170
Lincoln Roundtop 250 (Stick/GTAW)
Clausing 5913 Lathe
Gorton 1-22 Mastermil
Johnson J Bandsaw
3HP 220V Chop Saw-Chain Drive
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Tommy gun , Suzzi gun , don't much care if it's an Uzzi gun.
Dude makes a sword that splits 6 - 9mm slugs before die'N
some preople's kids![]()
Phil
'cause the bark is worse than bite?
1: that M2 wasn't firin' Mil. Spec. ammo, but soft point lead.
2: a .50 M2, a .50 Barrett, a .50 AE, a 9mm, or a 22LR are going to do the same amount of damage to the blade if they all use the same alloy projectile. they use a .50 cal machine gun for show, "ooooh, a machine gun !!!!", why not fill a Claymore with 00 buck, REAL impressive.
ooooh, how 'bout a Claymore (mine) against a Claymore (sword)
Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
Thermal Dynamics Cutmaster 52 Plasma * Lincoln 175 MIG
Victor Superrange II * Victor Journeyman
Hobart HH 125EZ
Hobart HH 125EZ
THAT is impressive luck being able to hit not only a blade on edge, but the same spot more than once with that .50 set up the way it was! It takes me a bench rest and my nail-driving 22-250 to hit the same spot more than once. I could hit the blade alright, but not full-auto on a swivel tripod!
Yeah, the soft lead debate I have a problem getting my mind around, too. 50-cal and .22LR soft lead rounds have different mass and velocity. It's like saying hitting water at 5 MPH is the same as hitting it at 50 MPH. Not quite the same. That was definitely NOT FMJ!!
I NEED MORE COWBELL!!!
'Red' Powcon 300ST (no torch yet)
(ok, not really a 'Red'...)
'Blue' Miller 35 (older than me and runs great), Thunderbolt AC arc (ditto)
'Craftsman' AC arc (who made this originally?)
O/A x 2 (both smaller than I'd like)
14" Milwaukee chopper
20t HF press (crap, but works)
Buffalo forge w/ blower
Alot of pumps!
"All of us know more than any of us."- TexHand
