Results 1 to 15 of 30
    S.E. Wisconsin
    4,552
    Thumbs up Pages of Japanese Sword Making
    Metal-work at it's Finest !
    http://www.youtube.com/watch?v=7wsIKMncpLY
    I could mezmarise for hours clicking from one to the next !!
    Phil
    5,320
    Interesting! I saw a museum-type display of Japanese swords one time at Texas A & M in the student center. Some were complete, some were just blades. Awesome. True devotion to the craft.
    S.E. Wisconsin
    4,552
    6 its from machine gun to brake it...!! on the 7th
    Tennessee
    1,166
    Wink
    zzzzzzzzzzzzzzzz
    Jul 2006
    NW Georgia
    183
    Quote Originally Posted by vicegrip View Post
    What was that, the japanese version of Mythbusters?
    Feb 2005
    wylie, tx
    390
    What was interesting to me was how the magic of the sword worked against the bullets. The edge, which is harder than a bad girl's heart btw, held it's own. It didn't break until the bullets had chipped away the hardened edge and reached the softer steel which gives the sword it's ability to survive repeated uses. Thanks for the link.
    S.E. Wisconsin
    4,552
    Quote Originally Posted by wroughtnharv View Post
    Thanks for looking deeper than the drama ......of the tommy-gun
    I was impressed at how many hits in the same region it took to start the breakdown.
    Phoenix, AZ
    248
    Talking
    Don't bring a knife to a gunfight.
    Hobart Betamig II
    Hobart Betamig 170
    Lincoln Roundtop 250 (Stick/GTAW)
    Clausing 5913 Lathe
    Gorton 1-22 Mastermil
    Johnson J Bandsaw
    3HP 220V Chop Saw-Chain Drive
    "You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
    Sep 2005
    Davenport, Iowa
    824
    .of the tommy-gun
    Not a tommy gun.....THAT was a Browning .50.....whole 'nuther animal
    Austin TX
    4,861
    Quote Originally Posted by TEK View Post
    About like comparing a Chihuahua to a Timber Wolf.
    Hobart HH 125EZ
    S.E. Wisconsin
    4,552
    Tommy gun , Suzzi gun , don't much care if it's an Uzzi gun.
    Dude makes a sword that splits 6 - 9mm slugs before die'N
    some preople's kids
    Phil
    1,559
    Quote Originally Posted by Zrexxer View Post
    'cause the bark is worse than bite?
    1: that M2 wasn't firin' Mil. Spec. ammo, but soft point lead.
    2: a .50 M2, a .50 Barrett, a .50 AE, a 9mm, or a 22LR are going to do the same amount of damage to the blade if they all use the same alloy projectile. they use a .50 cal machine gun for show, "ooooh, a machine gun !!!!", why not fill a Claymore with 00 buck, REAL impressive.
    ooooh, how 'bout a Claymore (mine) against a Claymore (sword)
    Austin TX
    4,861
    some preople's kids
    Yeah, and we all know that's what's really important in life...
    Not silly stuff like holding down a job or anything.
    Hobart HH 125EZ
    Austin TX
    4,861
    Quote Originally Posted by Pumpkinhead View Post
    By that line of "reasoning," there shouldn't be any such thing as a 12 lb sledgehammer, because a sledge is made of steel and a 8 oz ball peen is made of steel too, so they should have the same effect.
    Hobart HH 125EZ
    May 2007
    The wet northwest
    622
    How did he hit that blade?
    THAT is impressive luck being able to hit not only a blade on edge, but the same spot more than once with that .50 set up the way it was! It takes me a bench rest and my nail-driving 22-250 to hit the same spot more than once. I could hit the blade alright, but not full-auto on a swivel tripod!
    Yeah, the soft lead debate I have a problem getting my mind around, too. 50-cal and .22LR soft lead rounds have different mass and velocity. It's like saying hitting water at 5 MPH is the same as hitting it at 50 MPH. Not quite the same. That was definitely NOT FMJ!!
    I NEED MORE COWBELL!!!
    (ok, not really a 'Red'... )
    14" Milwaukee chopper
    Buffalo forge w/ blower
    Alot of pumps!
