You know something I don't? Last time I was out at my Dad's my MM 210 was still in our little shop , right next to the Migmaster 250.Dan, what were you using for the spray trans when you had a MM210?![]()
To spray arc with the MM 210 I use 98/2oxy. This gas mix requires a lower voltage and amperage then any of the common Argon/C02 gas mixes capable of producing a spray transfer arc. My MM 210 is capable of outputting 24 -25 load volts in the 200 - 210 amp range. With 98/2 and an .030 or .035 solid wire this output range produces a very solid spray transfer arc - I prefer the .030. Since both of these wire sizes transition over to a spray transfer arc at a lower amperage then 200 amps with 98/2, I can drop the out put down further, like 24 -25 load volts and 180 amps, and I am still producing a solid spray arc.
Miller has a habit of underrating these units. I would suspect both PM and MM will put out just about the same. One just has a super snazzy blue paint job.
