Results 1 to 4 of 4
    Suffolk Virginia
    1,734
    Nomenclature/Decal Question
    Just returned from a long road trip to the camp (560 miles one way). Saw a lot of trucks (I have a two wheel drive F150 myself). I understand the 4x4 on the rear fenders of countless 1/2 ton and 3/4 ton trucks, but why do the 1 ton duallies with power to both axles say 4x4? Shouldn't it be 6x6, or do two of the rear wheels fall off when they engage the transfer case?
    Blacksmith
    Big cheap (Chinese) Anvil
    Hand cranked coal forge
    Freon bottle propane forge
    HH 210 and bottle of C25
    May 2007
    Grande Prairie, Alberta Canada
    126
    Think of it as 4 (wheel positions) x 4 (wheel positions driving)
    See if that makes more sense. It's the same on the Class 8 side. Tandem steering axles & tandem driving axles with all wheel positions driving is called an 8x8. It's just how it is.
    Later,
    Apr 2007
    South Carolina
    376
    Wink
    A 2X4 uses one differential.
    A 4X4 uses two differentials.
    A 6X6 uses three differentials.
    I suppose you could label it a 4X6, but technically speaking, a "Dual Rear Wheel" is a composite assembly combining two rims into one, so you still only have two differentials turning a total of four hub/wheel assemblies.
    Army "Deuce 'n a Half" trucks and 5-Ton Trucks are good examples of true 6X6's: three seperate axles with three seperate differentials.
    HOBART Champion 10,000
    HTP MIG 2400 c RSG250 Spool Gun
    HTP Invertig 201 AC/DC - WANTED!!
    Lincoln PrecisionTIG 185
    Smith O/A Rig
    Clark 1/2" Floor Drill Press
    Clark 6" Bench Grinder
    DeWalt 4.5" Grinder
    DeWalt 4.5" Grinder #2
    DeWalt 4.5" Grinder #3
    B&D 18V 3/8" Drill
    B&D 18V 3/8" Impact Driver
    Now in order to kill the enemy, our men must be roused to anger; that there may be advantage from defeating the enemy, they must have their rewards. ~Sun Tzu in "The Art of War"
    Suffolk Virginia
    1,734
    Thanks. I see the logic now. I remember the old 6x6 military trucks with 2 rear drive axles.
    Blacksmith
