Check out the Modern marvels program on the History channel right now.There is a quite interesting structural welding segment airing,as I speak.
tooldude56
tooldude56
Lincoln Square Wave Tig 255
DC600/LN7
XMT 304/64 feeder W/ digitals
Esab PCM-875 plasma
2 -Oxweld O/A ,W-17/CW-23 torches,R-77 2 stg reg.
new Clausing Metosa SM1560VS Smart lathe CNC/Manual
Wells index 12x48 mod. 847 vertical 3HP. mill,3 axis DRO,3 axis PF.,Maxi-torque-rite PDB.
Dake #3 arbor press
Kalamazoo H9AW hor. metal saw
16" Kolley vert. metal saw,
Trinco 36" blast cabinet with collecter
All Snapon
huge Summit vert. bandsaw
6x18 Reid Rollerway surface grinder
I am watching it tonight. There are some good pictures from Liincoln. They did a lot to advance welding back when rivets were king.
It was a pretty good show, but Im a newbie so what do I know?![]()
They had nice clear video of a stick weld in progress...closer view than when youre actually doing the welding.
They also had a short segment on explosion welding, that was pretty cool![]()
I was all set to watch it but it was a long, tough day yesterday so . . . I fell asleep and slept through most of it. I hope it's on again.
Saturday, 7p.m. eastern
I starting watching that episode and that is amazing. 30 man hours on 1 weld. Talk about time consuming but critical.
I was surprised they didn't cover more O/A welding. The pretty much went from rivets to SMAW.
I agree. Also, the way they focussed on Lincoln Electric makes you wonder a bit whether that company had financially supported the show. It wasn't a marketing piece by any stretch as Lincoln was apparently the company that pioneered electric arc welding but it was notable that they were the only arc welding story told.
I thought it would have been a better show if they had spent a bit more time on the developments of arc welding over the past hundred years or if they had discussed things like aluminum or plastics or gone a bit more into how critical welds on submarines etc are done. On the other hand, the part on explosive welding was great and I had never heard of that before. I can't wait to get a 110 volt explosive welder from Home Depot for use in my garage.![]()
