Results 1 to 6 of 6
Thread: Auto-Darkening
    Jul 2003
    Jax,FL
    11
    Auto-Darkening
    I've having trouble adjusting the Var shade control to see what I was doing during welding. It seems that the var shade control weither set at #3 or #13 has no significant chance in light. I should be able to see at least my work piece rather than the just the arc. Any advice to this hi-tech Hobart hood is appreciated. I may have a bad switch,
    Southern California
    706
    artstang,
    Bob again. Stand in a door way with a bright sunlit scene in front of you. Set up an bare incandecent light in front of you. It will trip the auto dark. Much easier holding the helmet in front of you instead of wearing it and trying to sustain an arc. You can check shade shift (or lack of) and uniformity across the lense.
    Bob
    Jul 2003
    Jax,FL
    11
    Thanks Bob, I'll try this setup tomorrow, hopefuly this will work. If no luck, Hobart may have sent me a bad hood.
    Hobart Expert Rock Guest
    ARTSTANG........... Where are we with the helmet issue......... Please advise if you need help............. We can help.......... Be Safe.....................Rock....................
    SSCOTT@MILLERWLDS.COM
    Jul 2003
    Jax,FL
    11
    Unhappy
    Rock, I tried Bob's suggestion and only little improvement. Considering there is enough sunlight in the morning around my garage, but the length of the elec. cord limits me the mobility of the welder. I'm begining to suspect that the new hood has a bad var. shade switch, because I didn't notice any shade change switching from #9 to #13. I've done everything the manual mentioned. I'm afraid this has to be warranted. It is a nice helmet, very patriotic. Thanks for the reply.
    ARTSTRING.......Give myself or Steve a call here today at 1-800-332-3281 or when you get a chance.......... Someone is here from 07:00 est until 05:00 cst........you may also get to talk to Mike, Marie, Doug, or Kevin if you can't catch us.............. That is 11 hours of service...........Be safe now......................Rock.....
    SSCOTT@MILLERWELDS.COM
