Results 1 to 4 of 4
    Feb 2007
    158
    Multimaster 260 possibly?
    http://products.esabna.com/index.htm...ategory_id/122
    WOrth the money or no? where would be the best place to get it. By the way I dont weld aluminum even thoug h Ican I just dont have any use for it. Thanks!
    3,339
    Quote Originally Posted by RossTheWeldor View Post
    Depends what you want your welder to do??? Do you need pulse mig??
    Your local welding store should be able to match the internet on that machine.
    Depends if they want too? I been very impressed with mine, because it's
    just a very solid unit overall. It's has a bit different type arc then most machines.
    The best way to describe it's almost a inverter type arc but not exactly. At least
    the inverters I have used. It has great arc starts and plenty of adjustably with
    it's optional inductance control. Everything is a option except the burn-back control
    and the dual bottle rack.The stick and tig arc are really nice too. Lift-arc only but
    you would have a heck of a time telling it from a inverter tig machine. The specs
    are wrong on the tig arc because it goes down to one amp on the low-end and about
    312 on the high-end (DC only) I like it because it has pretty cheap circuit boards and
    not too many either.
    Esab 200 caddymig
    Esab 1600 powercut plasma
    Thermal 186 AC/DC
    Thermal Arc 400 MST(Right stuff!)
    Ultrafeed 1000
    Thermal Scout 170 engine drive. (killer little unit)
    Thermal Pee-wee 85s
    Smith O/A plus mini torch
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
    Remember good judgment comes from experience, experience comes from bad judgment.
    Feb 2007
    158
    Does the tig come with a foot pedal by chance? How dependable of a welder is it compaired to hobart and miller. I honestly LOVE millers arc on there bigger multiprocess machines but most of them are too expensive for me. I like my hh140 but want somthing a little stronger I never could get a good weld or feeling out of a lincoln I just didnt like lincoln welders at all they seemed inconsistant if you ask me... anything you could relate this machine too? I almsot want to try it before I buy it in a way.
    3,339
    You need to find a welding store with a demo setup. The Esab welds like no other machine
    I have used but it was kind of between a Lincoln 255 and MM-350p. That would be the arc
    quality but with a better wet out then the 255. What that means is you can run a crisper
    type arc but still have good wet-out. I do like it better then the new Miller Shopmate, but I
    really never ran that one long enough to really know what that machine has. The Esab is just
    a good machine until you add the inductance control. For some reason it just turns it into
    a totally different machine. I am with you on the Lincoln machines. I ran really good ones
    and others of the same type and wonder what is wrong with it. The last PM-350 I used was
    half the machine my 300 was. The synergig .035 (#11) control was just out of whack. The
    Esab kicks that machines butt in the short-arc. Although on the standard #5 mig setting the
    PM-350 did much better.
    You need to buy the foot-control extra for the Esab.
    The 260 is a reliable welder because it's been out for quite a long time.
    Esab 200 caddymig
    Thermal 186 AC/DC
    Ultrafeed 1000
    Thermal Pee-wee 85s
    Smith machine torch
    LN-25 pro
    LF-72 feeder
    Edwards 65 ton
    5X10 CNC table
