Results 1 to 2 of 2
    Texas
    10
    Drill Press Help!!
    I 've run across an old Champion Drill 20". It works just fine & has the 3 Phase convertor that goes with it. No drills for the taper, but has the adj. chuck.
    The man is asking $600.00 for it.
    Does anyone know what this should be worth?
    P.S. The table swivels, lowers, & turns.
    Hope I have made enough since for you guys to understand.
    Thankyou for any help.
    John
    harwich, ma.
    455
    check spindle bore taper size. #2 is a little too small. #3 or 4 is better. if it's a 3ph motor it's probably more than 1hp[that's good]. the phase converter maybe be more valuable than the press. you can use it to run more 3ph machinery. chip
    chip
