Hi Folks,
Ran out of my sample roll of .030 FC wire that came with my HH140. Bought a new roll, but it has a little different part number. Could someone explain the difference, please?
Thanks, Russ
Hi Folks,
Thanks, Russ
Plain and simple GS sucks. Buy a nice roll of Lincoln NR-211 and be happy. I run 5/64 211 almost every day, and keep a roll of .035 211 for my MIG at the house. It is great all around wire, runs smooth, and the slag falls right off of it.
"Weld It And You Won't Be Screwed"
Rescued from the boneyard SA-250 on a fully equipt trailer (My Wife's Explorer cries every time I hitch up)
Trailblazer 301G (can't touch the SA-200 for stick)
Arcair K-4000 A.K.A "The Hissing Cobra"
HF- 251 TIG box for the TB with a Weldcrap torch, Yes I weld aluminum![]()
More than a toolbox full of stuff on an F-350 that is way to small
AFAIK, GS means the wire is certified to the standard the manufacturer decides on which can vary a fair bit from place to place. If I'm wrong someone here will chime in and we'll all learn another new thing.![]()
Craftsman 230a Buzz-box, Century MIG, Victor O/A
Grinders: Old green B&D, 2 x CTC, 14" cheapo chop saw that cuts straight and square!
Two 5cfm ganged compressors = 10cfm on the cheap
"Everyday" hand tools all old reliable Husky/Craftsman/Proto
Safety is my current passion.![]()
The spec for GS is "as agreed upon between customer and manufacturer", so you never know what you're going to get. I like the Hobart Fabshield 23 fine, but there are other formulations that don't run as well.
If you buy -11, it has to conform to that specification.
I've run the Lincoln, Hobart, ad Radnor -11 flux core wires, and liked the NR-211 best, but I much prefer GMAW.
Thanks Hank, that's what I was trying to say![]()
A E71T-11 must meet certain mechanical properties and must be capable of multipass . As already mentioned but Hankj a GS and G suffix means that properties are "agreed upon " so it can be anything. There is NO mechanical testing required ( tensile , yield, impact, elongation etc )
It does not mean that the electrode is no good , it just means it does not have to to through any testing and meet any criteria.
For example, the new and improved general purpose self shielding flux cored like Lincolns NR212 is "better" mechanically than all T-11s but does not fall into any standard catagory so it must be classified as a E71T-G. This electrode goes through all the mechanical testing and is reported on the CERT
BTW if its GS its for Single pass only. ( G is multi pass ) so be carefull what you use it for
You guys are a great resource. Thanks so much.
Is there a self shielded wire that is geared toward rusty metal outdoors?
Thanks again, Russ
