Results 1 to 4 of 4
    Oct 2002
    Hobart TIG Wave Info
    Anybody have an idea what year model is a Hobart Tig Wave Serial # 91W524162? Would you say that would be a good machine for a small shop performing TIG work aluminum or stainless steel?
    Hobart Expert Rock Guest
    HI MGSCARABO.......... THIS IS A CONSTANT CURRENT SINGLE PHASE MACHINE...... 230/460/575 AND WILL ALSO RUN ON 208 AT REDUCED OUTPUT........STICK AND TIG AC/DC...... NICE MACHINES I OWN ONE MYSELF....... RESPONSABILITY FOR MACHINE WAS TRANSFERED TO THERMAL ARC WHEN ITW AQUIRED HOBARTS IN 1995-96. THEIR NUMBER IS 1-800-462-2782 TALK TO MIKE, BILL OR BILL................. BOTH BILL'S OR MIKE CAN HELP YOU OUT....... HAVE SOME FUN WITH IT YOU WILL LIKE IT..........ROCK
    SSCOTT@MILLERWELDS.COM
    FORGOT TO ADD
    MGSCARABO...............AND THE YEAR IS 1991, THE ONE I OWN IS 1990....... GOOD LUCK WITH YOUR DECISION.......ROCK
    SSCOTT@MILLERWLDS.COM
    Troy, Oh
    214
    This is an excelent welder for welding aluminum and stainless steel. It has a High frequency control that will help start the arc with out having to scratch start the tig. This really helps in the aluminum process.1991 good welder.
    Dave Evans
